No power to anything on car!!!!!
Old Sep 29, 2011 | 04:43 PM
l98iroc444's Avatar
This is my first post on thirdgen.org, so I appoligize for possiblly posting wrong and sounding unexprienced. I have a 1987 iroc-z with the 5.7 and automatic. I have been slowely going through everything replacing stuff. I put a new mtor in it this summer and luckily it fired right up. I had no problems other than my front seal on my transmission leaking. I decided to pull it out, have it rebuilt and put it back in. Today I finished putting everything in. The battery was dead from sitting so I jumped it using my other car. I turnded over the key, and clicked as if I didn't have enough power. So i decided to also hook up my battery charger to it. As soon as I did this everything died. I have absloutly no power to anything electrical in my car. I also heard a faint buzzing and possibly a wiff of smoke, but I see no burnt wires. Also I realized my cables were getting hot, so I took them off. I tried hoking power up to just the started + side and still nothing. I tried to search forums on here and I think it is possibly a bad starter solenoid? Or possibly a bad fussible link? Any input, help, or direction to an appropriate thread would be greatly appreciated.
Old Sep 29, 2011 | 04:47 PM
ternandes's Avatar
Car: 88 GTA
Transmission: WC T5
Axle/Gears: BW 9-bolt 3.27 posi
Re: No power to anything on car!!!!!
Are you sure you didn't inadvertently reverse the charger polarity when you connected it?
Old Sep 29, 2011 | 04:49 PM
l98iroc444's Avatar
It is possible but I I don't think so.
Old Sep 29, 2011 | 05:14 PM
ternandes's Avatar
Car: 88 GTA
Transmission: WC T5
The scenario you describe could easily have been caused by a reverse polarity "jump". I would carefully attach the charger to your battery with one cable disconnected and see if it charges the battery. If it does, then I would reconnect the cable after the battery has fully charged and see what you have.
If it doesn't, then I would suggest trying a different charger on your battery with one cable disconnected.
BTW, it's always a good idea when making connections like jumper cables or a battery charger to tap the terminal with the clip before attaching it just to make sure that you don't have reversed polarity or a dead short somewhere.
When you say your cables got hot, was that just sitting, or only while trying to turn the starter? When I see your answers, I'll try to help you.
Old Sep 29, 2011 | 05:42 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
ive done the whole reverse polarity thing before....it tends to blow a lot of fuses. you might wanna give the fuse box a going over.
but i agree, the symptoms you posted sound exactly what happened when i hooked up the charger backwards.
Old Sep 30, 2011 | 12:19 PM
l98iroc444's Avatar
Well I looked everything over fuses and everything, and realized that the main power wire got melted to the underside of my header, creating a huge short. I feel stupid now for asking but I am happy to see my car running and hopefully take it for a drive tonight for the first time! Thank you for taking the time to reply.
Old Sep 30, 2011 | 01:50 PM
travis401's Avatar
Car: 91 Camaro RS
atleast it was something easy
Old Sep 30, 2011 | 02:21 PM
ternandes's Avatar
Car: 88 GTA
Transmission: WC T5
Good catch. I'm glad you are up and running. DRIVE that thang!
BRoss99
Aug 10, 2025 05:08 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Brcharrelson
Aug 26, 2015 07:47 PM
novaderrik
Aug 10, 2015 12:44 PM
