IROC won't start up after several tries - security issue?
Old Oct 17, 2011 | 01:01 PM
89IROCZZ4's Avatar
Sometimes when working on the IROC, it may take a few tries to get it started. If it takes more than 5 or so, it is like the security system kicks us out from the motor even trying to turn over. We have to wait 5-10 minutes and it'll try for us again. What causes this, and can this be stopped?
Old Oct 17, 2011 | 01:07 PM
NullHead's Avatar
Car: 1991 Pontiac Firebird
Engine: 305 TBI
Axle/Gears: 3.73, Detroit Trutrac, 10 bolt
Re: IROC won't start up after several tries - security issue?
Long slow cranks, fast cranking with no starting, rough starts, what exactly is it doing?
Do you have spark/fuel when it has these episodes?
Old Oct 17, 2011 | 01:16 PM
89IROCZZ4's Avatar
I believe it is long slow cranks. It may just be that there were issues with the car so hopefully I won't run into it again.
Old Oct 17, 2011 | 03:36 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
any cranking at all leads to something other than a VATS issue, unless the start enable relay has been bypassed.
Old Oct 20, 2011 | 09:23 PM
KidwithIROC's Avatar
Car: 1989 Iroc-Z
Engine: 5.7 350 TPI
Axle/Gears: 2.77
Ill let my car sit in the parkinglot while im in school and it wont start when i get to it at the end of the day. but then i hook up a battery starter, and it fires right up. What i dont understand is, that it'll sit all night and start up like a champ. We have replaced the battery, starter, ignition control module, ignition cylander, battery wires, spark plugs, soon the wires too. we also checked for any draws. Any ideas?
Old Oct 21, 2011 | 03:22 AM
travis401's Avatar
Car: 91 Camaro RS
when it doesnt start, is the security light in the dash lit solid?
Old Oct 22, 2011 | 08:58 AM
Car: 1989 Iroc-Z
Engine: 5.7 350 TPI
Axle/Gears: 2.77
Nope. we thought the V.A.T.S. system was locking us out for 15 minutes every time but it would crank too slow to start the car and we had fuel pressure so that wasn't the case. it's intermittent crank no start. the car will work perfectly in every way for about a week and then it wont start. i hook it up to a battery charger and then the whole process starts over.
Old Oct 22, 2011 | 09:04 AM
Impaqt's Avatar
Car: 88 Iroc-Z Convertible
Have you checked the alternator? Sounds like your battery isnt being fully cahrged.
Old Oct 22, 2011 | 09:52 AM
Car: 1989 Iroc-Z
Engine: 5.7 350 TPI
Axle/Gears: 2.77
Yep. The alternator is good. The starter was drawing 400 amps and that starter eventually went bad so it has a brand new starter. so now it isn't drawing anymore but that didn't solve the problem. we checked for other draws and there aren't any.
Old Oct 22, 2011 | 10:16 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
For a draw test, I assume you have connected an ampmeter between one battery post and the disconnected battery cable with the key off. Look for any more than .2 amps draw, assuming you have an aftermarket stereo. You say your alternator is okay but have you tested its voltage and amp output on the car while running all your lights and accessories? You may have a wiring or fuse issue that causes it not to work on the car even though it tests okay on the bench.
Your battery, even if it is new may have a bad cell that prevents it from maintaining a charge. I see it often with certain major chain store batteries. If you have performed the draw test as detailed above and checked the alt output on the car, you may just need to try a different battery. If the car starts well for days after the battery is charged then one day wont start, and you've verified no excessive draw and a healthy start/charge system, you have to suspect the battery.
Old Oct 23, 2011 | 12:35 PM
Car: 1989 Iroc-Z
Engine: 5.7 350 TPI
Axle/Gears: 2.77
Our next step was the battery. we originally changed the battery when the problem first started. What we are starting to think is that the battery we got was junk. but yeah we would check the alternator with everything on. Im going to change the battery this week, as well as put a fuel pressure gauge on there to see if the fuel pump is giving off enough pressure because it does prime, but we just want to be sure.
Frozer!!!
Jan 19, 2024 04:55 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
Tonyy_z
Aug 12, 2015 07:20 AM
mustangman65_79
Aug 11, 2015 03:17 PM
