starter compatibility question
Old Oct 22, 2011 | 11:34 AM
dark scorpion's Avatar
Car: 1990 gta
Engine: 5.7 l 350 v8
Transmission: automatic
Hello all,
Luckily it's been a while since I needed help with my car.
The latest issue is with my starter. I want to replace my faulty starter with
a smaller version.
I googled information and it lead me to a camaro forum that stated a starter
from 93'-97' will also fit 82'-92' thirdgens.
My question is to verify if that is true???
The forum stated that the 93'up version is smaller and would fit into the spot
easily without having to remove the y-pipe.
Need responses asap as my starter won't last much longer and I would like to
fix it by next weekend. Don't want to get stranded any where with my 2 year
old in the car.
Thanks.
Old Oct 22, 2011 | 11:52 PM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
Re: starter compatibility question
Why do you want a smaller starter? CSR sells mini starters but they get quite expensive.
Old Oct 23, 2011 | 03:00 AM
Aaron_SK's Avatar
Car: 1985 Sport Coupe
Engine: 3800 Series II Turbo
Transmission: 4th-gen WC T5
Axle/Gears: 3.27 BW Limited
Because he has headers, or a high compression engine, or he's tired of the Chevy solenoid heat problem.
I have run Lt1 starters and had good luck with them. Need to make sure yours is a 153-tooth flexplate (make sure the starter bolts line up, and are not offset).
Old Oct 23, 2011 | 06:29 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Need to make sure yours is a 153-tooth flexplate .
The factory Denso unit used on the late Vette L98's and LT1's is a popular compact unit.
Half the weight of Delco unit
Old Oct 23, 2011 | 08:36 AM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Go to Jegs, can get a High torque mini, will fit either size flywheel for about$140, suckers work great....
Old Oct 23, 2011 | 11:37 AM
Car: 1990 gta
The bolt pattern is offset.
The other thing was I didn't know if it is 153 tooth or the other. How can you tell?
Yes I am tired of the heat solenoid problem and I will be getting headers shortly after christmas and since I have stater problems now, might as well get one that will accommodate having headers.
Was looking at the mini starters from jegs and summit, will have to revisit those sites.
Thanks for the responses.
Added info: 90 gta w/ 5.7 350.
Old Oct 23, 2011 | 12:58 PM
Aaron_SK's Avatar
Offset bolt pattern = 168 tooth flywheel, so someone must have swapped an older engine into your car. You need a mini-starter, LT1 will not work.
Old Oct 23, 2011 | 01:44 PM
Car: 1990 gta
So same length bolt pattern-153 tooth
Offset bolt pattern-168 tooth?
Old Oct 23, 2011 | 03:31 PM
Aaron_SK's Avatar
Yes, take a look:
Old Oct 24, 2011 | 12:31 PM
Car: 1990 gta
Slight error on my part as when I looked at my starter I mistook the long and
short bolt holes as being offset.
I had my car in the air today and observed that the holes are lined up and
are NOT offset as seen in the pic above.
That being said, the 93 and up starter will fit my gta right?
Old Oct 24, 2011 | 08:46 PM
Aaron_SK's Avatar
Yes, LT1 starter will work and will be an improvement in power, size and crank speed. You could use an LT4 starter as well.
Old Oct 29, 2011 | 08:36 AM
Car: 1990 gta
UPDATE!!
24 hours removed from installing the smaller lt1 starter and I am
extremely happy.
Installed with no mods and works great!
Thanks guys.
Old Oct 29, 2011 | 10:22 AM
Aaron_SK's Avatar
Anytime, dude. The LT1 is a good unit.
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
Cleotiz
Aug 22, 2015 01:54 PM
redmaroz
Aug 16, 2015 11:40 PM
milk
Aug 10, 2015 06:26 PM
