Best area to wire this in..
Old Oct 28, 2011 | 07:35 PM
royrabb's Avatar
Car: 1991 Pontiac Firebird
Engine: 5.0 TBI
Transmission: 700-R4
Axle/Gears: 2.73 ugh..
Hey all,
I got the VATS module here that mimics the pulse to kick everything on. Only problem is, all the threads I've managed to find say a certain number of wire (colored blue) to put it on. I am gathering it needs to go in between my ECC and the module that is buried in the dash.
The thing is.. in the harness going into my ECC there are about 5 blue wires and nothing is labeled, not even on the inside of the ECC. Am I SOL here or do I just need to locate the buried VATS box and then trace it back to the ECC? An idea that I don't have to do that would be optimal as I've read that is a real PITA.
Attached Thumbnails Best area to wire this in..-2011-10-25-12.33.56.jpg   Best area to wire this in..-2011-10-25-12.34.39.jpg
Old Oct 28, 2011 | 07:59 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Best area to wire this in..
should be pin b6 on the 1228746 tbi ecm
Old Oct 28, 2011 | 08:02 PM
royrabb's Avatar
Engine: 5.0 TBI
Are the individual pins labeled up inside where the connector plugs in? I didn't look there. I don't have it with me here or I could look. haha
Old Oct 28, 2011 | 08:12 PM
Engine: Lb9
Transmission: M20
no look at a pinout, did that thing come with a instructions?
http://www.diy-efi.org/gmecm/ecm_inf...6/89FTBI_4.JPG
https://www.thirdgen.org/forums/elec...6154-vats.html
Old Oct 28, 2011 | 08:16 PM
royrabb's Avatar
Engine: 5.0 TBI
The first pic.. just generic ones that say 12+, ground, the VATS line.. etc.. haha Nothing nearly as specific as the link you provied. Thanks for that man!
Engine: Lb9
Transmission: M20
np
Old Oct 29, 2011 | 11:19 AM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
those things are ment for a wide range of cars, each one has a different pin location on the harness. so thats why you get generic instructions. if youre bypassing VATS, you will also need to ground out the start enable relay for the starter to spin.
Old Oct 29, 2011 | 11:39 AM
royrabb's Avatar
Engine: 5.0 TBI
Does that relay have a pin on the connector (I didn't see it on the pic) or is that part of that small little "junction" as I call it that mounts to the radiator support near the battery?
I get lost in all the relays these things have.
Attached Thumbnails Best area to wire this in..-2011-10-17-16.26.06_6_kansas_us2.jpg
Old Oct 29, 2011 | 11:45 AM
travis401's Avatar
Car: 91 Camaro RS
the start enable relay is in the cabin, under the driver side kick panel
1992 Trans Am
May 10, 2023 07:19 PM
Lmancha96
South Central Region
Oct 22, 2020 12:40 PM
sinisterGTA
Pacific Northwest Region
Aug 23, 2019 10:25 PM
87 camaro iroc
Jun 24, 2016 06:06 PM
Dialed_In
Aug 20, 2015 01:45 PM
