Need help removing an old alarm
Old Oct 30, 2011 | 08:05 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
Hi all,
An aftermarket alarm has been on my car since I bought it ten years ago, and I've hated it. I'm trying to remove it and have all the wires traced but need help on two wires:
There's a red wire from the alarm that is spliced into a larger gauge yellow wire (see pic #1 please). It appears the other half of the yellow wire is spliced with a black ground wire (also in pic #1). Should I just remove the two spliced wires and re-connect the yellow wire? What is the yellow wire?
Second there is a aqua color wire that comes off the alarm that runs to a blue wire, which then runs into the center console area (see pic #2). I cant find what the blue wire would normally connect to... any ideas?
Thank you
Chuck
Attached Thumbnails Need help removing an old alarm-2011-10-30_16-51   Need help removing an old alarm-2011-10-30_16-51
Old Oct 30, 2011 | 08:42 PM
iammbs's Avatar
Re: Need help removing an old alarm
The Yellow wire is for the starter. Yes, just reconnect the two yellow's. The blue wire "may" be going to the switch for the hatch release.
Old Nov 5, 2011 | 07:43 AM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Axle/Gears: 3.79
Thank you! Got the alarm out and got the car started this morning.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
ctoledo0834
Sep 18, 2015 04:16 PM
Stroopwafel
Sep 11, 2015 06:38 AM
