tpi harness issue
Old Nov 26, 2011 | 08:47 PM
tonys91rs's Avatar
Car: 91 Camaro RS
Engine: 305 TPI conversion.
tpi harness issue
ok techs. i have a problem. im doing a tpi conversion from a 91 tbi and have posted in the tpi section. it is a 92 speed density harness with no appearent modifications. i have no power what so ever. turn the key and nothing at all. no headlights, fuel pump, nada. with a test light im getting power to the harness. volt check shows 12 volts to the battery. fog lights run only from battery and work. so its not battery..
the connector near the battery with one orange and red wire was repaired. the orange wire was cut and repaired. after the factory connection there is power. i checked the plugs ins and dont see nothing. ground straps and connections are checked and secure.
fuse mounted near battery on the inner fender wall is good and getting power.
vats?
fusible link?
possible problem at the black plug near the master cylinder?
repin?
what am i missing?
Old Nov 26, 2011 | 10:00 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: tpi harness issue
So, let me get this straight. You have have already installed the 92' tpi harness in the car with the tpi 1227730 ecm and proper prom (chip)?
Old Nov 27, 2011 | 06:31 AM
Pocket's Avatar
Car: 91 Trans Am
Even with no ECM plugged in and VATS on the fritz, it should still power up atleast the lights
You dont have 12v in all the right places. Check your fusible links again and make sure the two 12v wires near the battery are connected to a 12v source. You'll have to cut off the TPI specific connector
Old Nov 27, 2011 | 09:13 AM
tonys91rs's Avatar
Car: 91 Camaro RS
it is the correct harness, ecm and chip according to the numbers. there is only one connector to the positive side cable. it has connection to the starter cable and to the alternator.
the connector to be removed is a plug in that has a red and orange wire, which i repaired the orange wire. that is to be removed?
i will double check the fusible links and grounds and post back.
Old Nov 27, 2011 | 09:25 AM
Pocket's Avatar
Car: 91 Trans Am
Both red and orange wires need to be connected to 12v source
Old Nov 27, 2011 | 12:20 PM
tonys91rs's Avatar
Car: 91 Camaro RS
i do appreciate the help.
both red and orange are getting power at the battery, fuse and after the black connector. the red cable to the alternator is also getting power.
i see one fuse link combining red and orange and no other. ideas?
Old Nov 27, 2011 | 01:30 PM
tonys91rs's Avatar
Car: 91 Camaro RS
i rechecked the wires and get power to the relay block on the drivers side. i double checked the black connector under the relays. what am i missing?
Old Nov 27, 2011 | 02:22 PM
Pocket's Avatar
Car: 91 Trans Am
Check for 12v on the two big red wires at the C100 (near the booster)
They supply power to the IGN switch, fuseblock and light switch
Old Nov 27, 2011 | 02:36 PM
tonys91rs's Avatar
Car: 91 Camaro RS
ok i have no powerto either red wire at c100. where do i back track to?
Old Nov 27, 2011 | 02:37 PM
Pocket's Avatar
Car: 91 Trans Am
Fusible links on the starter
Old Nov 27, 2011 | 02:48 PM
tonys91rs's Avatar
Car: 91 Camaro RS
uh..no. i didnt see them tucked out of the way till i got under there. so. give me 10 minutes and ill post back the results. thanks.
Old Nov 27, 2011 | 04:40 PM
tonys91rs's Avatar
Car: 91 Camaro RS
i would like to express my appreciation to you pocket, as this resolved the problem. lesson here, check everything twice. she fired up and with a little tuning and timing shes good to go.
Old Nov 27, 2011 | 05:03 PM
Pocket's Avatar
Car: 91 Trans Am
Glad to hear it was something simple
Caspar
Jun 19, 2016 11:19 PM
jharrison5
Aug 19, 2015 05:53 PM
jbd1969
Aug 17, 2015 07:06 PM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
