Switching to carb.. what can i cut?
Old Nov 28, 2011 | 10:42 AM
89fbrestor's Avatar
Car: currently 91 camaro
Engine: soon to be 350 turbo
Transmission: soon to be 4l80e
Axle/Gears: 99 ss rear end with richmond 4:11's
hey guys just curious if there is a thread or if anyone knows a basic rundown on what i can delete from the wiring harness. i want it to be street leagal but i want to clean it all up in the engine bay as well. i pulled my 305 and am switching to a carbureted 350.
i'm not trying to get anyone to do my homework for me just a point in the right direction would be greatly appreciated or a thread that has already done this would be nice as well.
thanks guys and happy holidays.
brian
Old Nov 28, 2011 | 02:33 PM
ls1 hunter's Avatar
Car: 91 RS
Engine: 421 18 degree sbc.
Transmission: 2 speed glide from tci
Axle/Gears: 9" ford 5.29 gears
Re: Switching to carb.. what can i cut?
I'm in process of doin the same thing a thread would be great as I can't find a thread myself. Help would be greatly appreciated.
Old Nov 28, 2011 | 02:36 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
As a general guideline all the crap from the passenger side will go. Just make sure you trace stuff to sensors. Pull the ECM out.
Old Nov 28, 2011 | 05:26 PM
89fbrestor's Avatar
thanks internal, ya theres a big bundle going to the passenger side by the blower motor. im actually considering just pulling everything and doing a painless wiring set up.
ls1 hunter.... iv looked as well and ya a not finding much as far as step by step or someones build on this one. good luck, you might want to check out the painless wiring as well.
thanks guys
brian
Old Nov 28, 2011 | 11:04 PM
Car: 1992 Camaro RS
thanks guys
brian
Yeah I forgot about the A/C... make sure you keep that stuff. That's why you pull the ECM out. You dont want to cut your A/C connections.
Old Nov 29, 2011 | 06:37 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
The ECM harness is completely separate and removable, it's the only factory wiring missing from my previously carb-converted car. Keep it and the ECM stashed away in the garage somewhere.
For anything else you don't use - please don't butcher your harness - just tuck it away out of sight as possible. For instance, my PO was kind enough to leave the AC wiring present, even tho the AC was deleted. Now I want reinstall it, it's one headache I don't have.
Old Nov 29, 2011 | 02:48 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
you shouldnt need to really cut anything. the entire passanger side engine harness comes out with the ecm. theres a few wires that cross over behind the engine and connect into the driver side harness. fish those out and seperate them. the entire driverside harness needs to be untouched for the most part. youll tap into those wires for the gauge senders and power sources for the new engine. the ac wires can stay if youre keeping the ac, or can be pulled back into the cabin and the hole in the firewall filled.
Old Nov 29, 2011 | 03:52 PM
89fbrestor's Avatar
awwww ok i didnt know i the ecm thingy would take most of the wired on the passenger side. i seen that bundle and got a little freaked out lol thanks guys that clears some things up.
Old Dec 1, 2011 | 07:50 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
http://www.austinthirdgen.org/index.php?pid=19
best collection of harness info online. a helms manual also helps greatly.
psgr harness is ecm related, can be removed or tucked into the fender without cutting anything. about midway on the firewall is the ac/heat harness, leave there. driver side has the gauge and lighting harness.
Old Dec 1, 2011 | 11:21 AM
89fbrestor's Avatar
i printed it out thanks for the link. dan your always helpful thanks
brian
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
Caspar
Jun 19, 2016 11:19 PM
soarestransam
Sep 1, 2015 04:00 PM
Dialed_In
Aug 20, 2015 01:45 PM
355sbcTPI
Aug 19, 2015 04:38 PM
