Is this a starter problem or alternator
Old Dec 19, 2011 | 10:59 AM
Saicam88GTA's Avatar
Car: 88 GTA
88GTA
As of late I have notice if I drive a bit say 10plus minutes and stop the car the engine will not crank. I can hear the starter clicking and get a few attempts of the car tring to start real sluggishly but does not go all the way.
If I let it sit say 15 to 30 minutes I can get it started but it starts sluggishly for a few secounds then powers up.
If I lets it set a few hours It starts fine even though after a few key turn attempts i get the starter clicking a few times then fires up.
And recently the passenger side headlight has gone dim, dont know if the 2 are connected just yet.
Old Dec 19, 2011 | 11:42 AM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: Is this a starter problem or alternator
sounds like youre starter is either going out, or becoming susceptible to heat soak, and your headlight is going out. 2 separate issues.
Old Dec 19, 2011 | 12:54 PM
Car: 88 GTA
Just wanting to make sure the two werent a sign of anything. Figured it was the starter but wanted to make sure before I proceded to try and finagle the old one out.
Thanks for the quick reply.
Old Dec 19, 2011 | 01:08 PM
travis401's Avatar
Car: 91 Camaro RS
go with an LT1 starter. its a direct bolt in and smaller so its less likely to fail due to heat soak.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
db057
Sep 4, 2015 07:57 AM
Dialed_In
Aug 20, 2015 01:45 PM
92camaroJoe
Aug 13, 2015 06:07 AM
