Need help with diagnosing problem
Old Dec 19, 2011 | 09:46 PM
gschell's Avatar
I have a '85 Camaro Z28 with a 305 TPI. Recently bought & restored it. It runs good for about 10 miles and then the engine begins to miss and backfire through the intake manifold. When I accelerate, the problem gets worse. I have checked fuel pressure (runs 45 PSI at wide open throttle), replaced spark plugs, plug wires, cap/rotor, ignition coil, and ignition module. Compression check shows that it has good compression. ECM is not setting any codes. I would appreciate any helpful advice.
Old Dec 20, 2011 | 10:45 AM
85irocinjected's Avatar
Car: 1991 RS
Re: Need help with diagnosing problem
Even though you have replaced all those parts that does not mean one is not defective. Sounds like a heat soak issue with an ignition component. Usually its the pickup or the coil that have those kinds of issues. Since you did not replace the pickup I would check that.
pjsparts
Oct 29, 2025 06:39 PM
383cam
Sep 9, 2015 06:01 AM
Glowsock
Sep 6, 2015 06:40 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
