Ignition wiring
Old Dec 23, 2011 | 05:31 PM
kkingsrulee's Avatar
Car: 1990 Camaro RS
Engine: V8 305 TBI
Transmission: W/C T5
Axle/Gears: 3.08
Ignition wiring
My '90 RS 305 TBI is throwing a code 42, and it's a bit hard to start and idles a little rough. Other than that it runs fine.
I've been trying to determine the cause of the code, which states it's either an open or short in the EST circuit, a faulty ignition module, or faulty ECM.
I've tested the ignition module three times and all three times it came up good. I'm thinking there's a problem with wiring from the ECM to the ignition module.
Here's a reference I've been using
http://www.gearhead-efi.com/gearhead...c/TBIcodes.pdf
I'm not experienced at all with electrical circuits, though I have a multimeter.
Assuming I do find a problem with one of the circuits from the ECM to the ignition module, I'll have to tear through the wiring harness to locate this one wire and replace it, or what?
Any advice is appreciated, thanks.
Old Dec 24, 2011 | 06:52 PM
85irocinjected's Avatar
Car: 1991 RS
Re: Ignition wiring
With the hard to start problem, the problem is most likely a grounded EST line, circuit 423.
Check that first.
Also a PROM not fully seated in the ECM can cause a Code 42
Old Dec 24, 2011 | 06:58 PM
Car: 1991 RS
Re: Ignition wiring
Oh, just realized you said your not very good at electrical stuff.
To test if its grounded:
1. Turn ignition to OFF
2. Unplug ECM connectors
3. Turn ignition to ON
4. Set OHM Meter to 1000-2000 OHM Range
5, Probe ECM harness connector Circuit 423 with the RED lead on the OHM meter and the BLACK lead on a ground. It SHOULD read LESS than 500 OHMS
If it does not read less than 500 OHMs the you have an open circuit (no connection) or a bad ignition module (which you said tested good).
Old Dec 24, 2011 | 09:13 PM
Car: 1990 Camaro RS
Engine: V8 305 TBI
Axle/Gears: 3.08
Re: Ignition wiring
This is the part that's confusing me, when it says unplug ECM connectors, do I unplug the connection that is located AT the ECM, or the end that is located at the ignition module? Because the circuit runs from the ECM to the ignition module, so I'm confused as to whether I need to unplug the ECM connection at the module or the ECM.
Also, assuming I do find a problem in the circuit, because I know the module is good, then I know there's a short/open in the circuit then what should I do? Try and somehow track the short in the circuit down? That sounds very tedious.
Old Dec 24, 2011 | 09:39 PM
Car: 1991 RS
Re: Ignition wiring
Disconnect it from the ECU. Your testing what the ECU would see.
If you do find a short/open then yes you will have to follow that wire through the harness and find the break. Or you can cheat and cut the wire a few inches from each end and solder/splice your own. Then you wont have to open the harness and the crap wire is taken out of the circuit completely.
Old Dec 25, 2011 | 12:29 AM
Car: 1990 Camaro RS
Engine: V8 305 TBI
Axle/Gears: 3.08
Re: Ignition wiring
Good to go, I'll test it the day after tomorrow.
Old Dec 27, 2011 | 02:11 PM
Car: 1990 Camaro RS
Engine: V8 305 TBI
Axle/Gears: 3.08
Re: Ignition wiring
I tested it this morning, circuit 423 read .503 K Ohms. That's just outside of the 500 ohms it should be less than, what do you think?
Old Dec 29, 2011 | 05:31 PM
Car: 1990 Camaro RS
Engine: V8 305 TBI
Axle/Gears: 3.08
Re: Ignition wiring
Bump. Anyone??
Also, if I do replace the circuit 423 wire, what gauge wire should I replace it with?
Old Dec 30, 2011 | 10:08 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Resistance Is Futile
That circuit should read less than one ohm.
18.
Happy Racing!
He Must Have Been Be Cheating - Because I Was And He Almost Beat Me.
Old Dec 30, 2011 | 10:26 AM
Car: 1990 Camaro RS
Engine: V8 305 TBI
Axle/Gears: 3.08
Re: Resistance Is Futile
18.
Happy Racing!
Thanks for the reponse.
The circuit should read less than one ohm? So right now it's reading 503 ohms, thus it's reading 503 times as high as the normal resistance reading?
So there's most definitely a problem there, right?
Old Dec 30, 2011 | 11:03 AM
NINÅ's Avatar
Transmission: 765R4
That’s right.
Happy Racing!
Old Jan 2, 2012 | 09:05 PM
Car: 1990 Camaro RS
Engine: V8 305 TBI
Axle/Gears: 3.08
That’s right.
Happy Racing!
No dice. I soldered in a new wire about two inches from the ECM harness connector running all the way to about two inches away from circuit 423's connection to the ignition module (D4).
SES light still comes on about five seconds after starting the engine.
Old Jan 9, 2012 | 04:26 PM
NINÅ's Avatar
Transmission: 765R4
The Throttle Position Sensor can cause hard starting and ruff idle.
Make sure the sensor output isn’t more than 1.2 volts when your foot is off the loud pedal.
Happy Racing!
My Brakes Don’t Work AT ALL When The Car Is In The Air
Old Jan 20, 2012 | 06:46 PM
Car: 1990 Camaro RS
Engine: V8 305 TBI
Axle/Gears: 3.08
Re: Ignition wiring
Just figured I'd update you guys and anyone that has a code 42 problem.
I replaced circuit 424 (tan/black wire) and that fixed the problem.
So, if anyone experiences a code 42, check circuits 423 and 424, even though there might not be any visible damage at the ECM and ICM sides, there is likely a short somewhere.
BRoss99
Aug 10, 2025 05:08 PM
Caspar
Jun 19, 2016 11:19 PM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
Rakim_RS25TH
Car Audio
Aug 20, 2015 06:22 PM
Rakim_RS25TH
Aug 18, 2015 09:32 PM
