starter problems
Old Jan 2, 2012 | 06:14 PM
JAMES LOWE's Avatar
Car: 84 Z28 camaro
Engine: 383 stroker
Transmission: turbo 350
starter problems
I'm having starter problems on my 84 camaro 383. When i go to crank it, it grinds against the flywheel bad. I know it more than likely it needs shimming. Does anyone know what the gap distsnce between starter pinion & flywheel should be & what can i use to measure it. Its a mini starter & 168 tooth flywheel. My guess right now is that its to close to the flywheel. Could i possibly be using the wrong starter bolts,They are of the same length that came with starter, should i use the original/factory bolts? Any help greatly appreciated.
Old Jan 2, 2012 | 07:36 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: starter problems
http://cvrproducts.com/starter-technical-notes/
http://www.hotrodders.com/forum/chev...nce-67704.html
Old Jan 3, 2012 | 12:29 PM
JAMES LOWE's Avatar
Car: 84 Z28 camaro
Engine: 383 stroker
Do I need to change starter bolts? Do I need to use starter bolts with the knurls. It's a marine starter so Im not sure if the bolts that come with the starter are useful for automobiles. I went through 2 starters, if I put a new one on it's pretty quite & works fine for a while then starts the grind again
Old Jan 3, 2012 | 12:49 PM
dabomb6608's Avatar
Car: 86 Trans Am/85 K5 Jimmy
Engine: 406 FIRST/350 TPI
Transmission: TKO 600/700R4
Axle/Gears: 9Bolt/10Bolt front & back
Your supposed to use the bolts with the knurled ends. I would also assume your supposed to always use the new bolts. As long as they have the knurls. Thats what ive always done atleast. Im not sure if the marine starter is correct or not. I assume other then being more water resistent that it should be the same. As long as the teeth count are the same.
Old Jan 3, 2012 | 01:26 PM
JAMES LOWE's Avatar
Car: 84 Z28 camaro
Engine: 383 stroker
So would the bolts make it have that problem as far as grinding or is it a shimming problem. There are currently no shims on it now.
Old Jan 3, 2012 | 01:31 PM
dabomb6608's Avatar
I honestly dont know for sure if the bolts would have that much affect. Its possible i guess, all you can do is try.
How are the teeth on the flywheel? Are they eatn up any?
Old Jan 3, 2012 | 01:38 PM
JAMES LOWE's Avatar
Car: 84 Z28 camaro
Engine: 383 stroker
They look pretty good they are not ate up, but I wanna get it right before it does damage. Also I have a small oil leak from dipstick will that cause starter problems. It's getting on starter passenger side dipstick
Old Jan 3, 2012 | 01:52 PM
dabomb6608's Avatar
The leak wont affect it. My truck has a massive leak and it goes down the passenger side of the motor all over the starter and never had a problem.
Old Jan 3, 2012 | 02:19 PM
JAMES LOWE's Avatar
Car: 84 Z28 camaro
Engine: 383 stroker
Ok just checking, so u think I have a shimming issue
Old Jan 3, 2012 | 02:31 PM
dabomb6608's Avatar
Most likely, and i dont know much anything about shimming them. Ive never needed to shim any of my starters.
Old Jan 3, 2012 | 03:10 PM
JAMES LOWE's Avatar
Car: 84 Z28 camaro
Engine: 383 stroker
Ok thanks for your info. I'm going to try to shim it & see what happens. I have to get starter rebuilt because it's making a whining noise now it's not kicking out to the flywheel.
Old Jan 3, 2012 | 04:35 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Did you check clearances on them as you are supposed to when swapping starters?
What is "grinding" on the starters you are using up?
So would the bolts make it have that problem as far as grinding or is it a shimming problem..
Only if the bolts are too long and don't hold the starter to the block tight' letting it shift out of alignment
Old Jan 3, 2012 | 06:29 PM
JAMES LOWE's Avatar
Car: 84 Z28 camaro
Engine: 383 stroker
Sounds like it's hitting the flywheel too hard
Old Jan 3, 2012 | 07:04 PM
gp90gta's Avatar
Car: 1990 GTA
Most of those mini starters have large bolt holes, you can try first to just crack the bolts loose and move the starter away from the flywheel, then retighten them, if that dont work you can add shims, start with the thinnest one first, keep adding until the grinding goes away, you shouldn't need more then one or two.
Old Jan 3, 2012 | 07:18 PM
JAMES LOWE's Avatar
Car: 84 Z28 camaro
Engine: 383 stroker
Ok thanks I will try that. Just got my hands on another mini starter so is there anything I need to do different
Old Jan 4, 2012 | 09:25 PM
JAMES LOWE's Avatar
Car: 84 Z28 camaro
Engine: 383 stroker
What's the best kind of mini starter to buy that's not too expensive?
Spyder_TheGamer
Dec 25, 2015 05:07 PM
5spdcamaro
Aug 28, 2015 02:12 AM
92camaroJoe
Aug 13, 2015 06:07 AM
milk
Aug 10, 2015 06:26 PM
