Speedo question - 91 car 87 ecm and motor
Old Jan 16, 2012 | 08:17 PM
insomniac's Avatar
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
Question how can I get the speedo to work since my 91 is electronic and teh 87 ecm / motor being swapped in is from a 87?
Also if i work that out what kind of problems will it have now that the 87 computer has no speedo input and has no clue how fast the car is going?
the 87 also only uses the vss for lock up
Old Jan 16, 2012 | 08:37 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: Speedo question - 91 car 87 ecm and motor
First of all,what color is the wire from the speedo to the buffer?
Old Jan 16, 2012 | 08:38 PM
ninetyone's Avatar
Axle/Gears: 3:42
Should be a tan wire from speedo to buffer .OK
Old Jan 16, 2012 | 08:43 PM
ninetyone's Avatar
Axle/Gears: 3:42
Ok, now connect the tan and the brown wires together after you unplug them from the buffer box,cut and splice of course. Now trace that brown wire (K) to the ecm(the 207 connector really) Ok,pause there. I was assuming you were swapping a tbi to a speed density tpi not a Maf car, sorry. Cause Speed density does not use a buffer box and i bypassed mine after my swap was done. I will let you know what i come up with man.
Old Jan 16, 2012 | 08:50 PM
ninetyone's Avatar
Axle/Gears: 3:42
http://home.earthlink.net/~gellett/89wiring.gif
there is a wiring diagram for your 165 ecm,looks like you may have a buffer still? Let me check further
https://www.thirdgen.org/forums/elec...blem-cant.html
check that link too,there is a guy on here by the name of "pocket" he may know more than i do on swapping to MAF and your speedo info. Good luck
Old Jan 16, 2012 | 09:12 PM
ninetyone's Avatar
Axle/Gears: 3:42
87 tpi may use a different buffer box than a 91 tbi too,im not sure man.
Old Jan 20, 2012 | 10:21 PM
alex91z28's Avatar
Car: z28, g92, 5psi paxton,42lbs,eblp4
Engine: 5.7 .040bore,195cc trickflow,tpis
Transmission: 5spd
if your car was a tbi engine it came with a speed buffer that gave the speed signal to the ecm and the speedometer you might hook it up to that.
if your car was a tpi car they did not come with a buffer, since the speed sensor goes straight to the ecm and the ecm sends the signal to the speedometer. in this case you would need to get a buffer from a tbi car.
Old Jan 20, 2012 | 10:46 PM
ninetyone's Avatar
Axle/Gears: 3:42
ok that is your ecm pinouts. look at a10 the brown wire. that is a brown wire directly from your buffer box to the ecm. just trace the brown wire from a10 on your ecm. it should come out of ecm and stop at the c207 connector. make sure it leaves the c207 connector and goes to the buffer box correctly. so basically the other side of the c207 connector should also have a brown wire that goes to pin f on your buffer box. then it should work. then the signal should leave the buffer box on a tan wire that goes directly to speedo.
Old Jan 20, 2012 | 10:49 PM
ninetyone's Avatar
Axle/Gears: 3:42
the wiring looks the same on the 87 tpi and the 91 tbi concerning the buffer box, i am thinking maybe the 87 cars used the other type of buffer box.
Old Jan 20, 2012 | 10:52 PM
ninetyone's Avatar
Axle/Gears: 3:42
no, the earlier tpi cars used a buffer box too, now 90-92 tpi did not
Old Jan 20, 2012 | 10:54 PM
ninetyone's Avatar
Axle/Gears: 3:42
http://austinthirdgen.org/mkportal/m...ine_wiring.gif
look at that 1987 tpi used a buffer with a brown wire going to ecm and a black/wht ground wire
Old Jan 20, 2012 | 11:02 PM
alex91z28's Avatar
Transmission: 5spd
yes that right, but that was for the cable speedometer right. y think he is going to need a buffer from a 90 to 92 to get the electronic speedometer working and a vss signal for the older ecm.
Old Jan 20, 2012 | 11:03 PM
ninetyone's Avatar
Axle/Gears: 3:42
first of all have u re-pinned this car yet? and the speedo is the only problem?
Old Jan 20, 2012 | 11:06 PM
ninetyone's Avatar
Axle/Gears: 3:42
no, alex91z28. the 90-92 tpi did not use a buffer,but the 90-92 tbi did,but he already has a 91 ex-tbi car.so he has a 91 buffer box in there, its just a tbi box. the wiring at the 87 tpi ecm and the 91 tbi ecm look to accept the buffer output wire (a10) (brown wire) in the same spot tho (its A10) at the ecm.
Old Jan 20, 2012 | 11:08 PM
ninetyone's Avatar
Axle/Gears: 3:42
i think he needs to compare the 1987 buffer box against the 1991 tbi buffer box before anything, and remember be specific. look up 87 wiring not 88,not 1989 but 87'
Old Jan 28, 2012 | 09:56 AM
Pocket's Avatar
Car: 91 Trans Am
All buffer boxes operate the same way. He needs to find the VSS pins for the 87 harness and move them to match his 91. Rest is taken care of
If all else fails he can wire the whole circuit external
MustangBeater20
Oct 29, 2022 09:20 PM
Jorlain
Aug 24, 2022 05:11 PM
Irocohio
Aug 12, 2015 08:03 AM
beachrodder
Aug 7, 2015 04:27 PM
