instrument cluster lights do not work
Old Jan 18, 2012 | 04:51 PM
mickeypatches's Avatar
Car: 1984 camaro z28
Engine: 305 v8 h.o.
hi, im working on an '84 camaro z28 that my dad has and the instrument cluster lights will not come on. the headlights stopped working a little bit before i started working on this. i replaced the headlight switch and the dimmer switch and the headlights started working (well one of them did) but the instrument cluster will not light up. any ideas, trying to get the car working before senior year
Old Jan 18, 2012 | 05:54 PM
Seven_MPG's Avatar
Car: 1985 Z28
Engine: '69 350 4 Bolt Main .30 Over
Transmission: 700r4/B&M Shift Kit and Flywheel
Axle/Gears: GM 10 Bolt 3.23 Gears
Re: instrument cluster lights do not work
Did you check the fuse under the dash?
Old Jan 18, 2012 | 06:37 PM
Engine: 305 v8 h.o.
might of blown recently but last time i checked it was still good
Old Jan 18, 2012 | 08:16 PM
Engine: 305 v8 h.o.
checked fuse and it is good. also the gauges work it is just the lights dont
Old Jan 20, 2012 | 07:35 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Sorry, I have to ask: Have you tried twisting the headlight **** (which dims/turns off the gauge lights)?
JamesC
Old Jan 20, 2012 | 04:39 PM
Engine: 305 v8 h.o.
haha yes i have. i bought electric contact cleaning spray and gonna spray down the connectors and clean them pretty good. pray that this works
Old Jan 21, 2012 | 06:51 AM
JamesC's Avatar
Originally Posted by mickeypatches
i replaced the headlight switch and the dimmer switch and the headlights started working (well one of them did)....
Maybe some help below:
Headlights
Circuit Operation:
Voltage is applied to the light switch at all times. The light switch includes a self-resetting circuit breaker which opens and closes if the headlight circuit draws too much current. When the light switch is in "Head," the headlight dimmer switch directs current to either the lo beams or the hi beams. Current to the hi beams also flows to the high beam indicator.
Troubleshooting Hints:
If only one headlight doesn't work in both "hi" and "lo", check the ground wiring.
If headlights don't work in just "hi" or just "lo", check headlight dimmer switch.
If headlights flash on and off with switch in "head," isolate short to ground. Operate the headlight dimmer switch to find if the short to ground is in tan or lt grn wires.
If only the "hi'" headlights flash on and off, check lt grn wires for shorts to ground.
If only the "lo" headlights flash on and off, check tan wires for shorts to ground.
If both "hi" and "lo" headlights flash on and off, check the yel wire for a short to ground.
JamesC
Old Jan 23, 2012 | 11:38 AM
Engine: 305 v8 h.o.
i think the headlights just have bad bulbs, took one out a while ago and its bulb was bad. but which wires should i check that go to the instrument cluster?
Old Jan 23, 2012 | 04:37 PM
ZF6camaroZZ4's Avatar
Car: 86 Z/28 IROC-Z
Axle/Gears: 9 Bolt 3.27
Dk/Grn comes off the head light switch dimmer to the cluster. See if you have voltage coming off the dimmer, and see if you have continuity on the wire from the switch to cluster.
Cluster lights have a couple grounds, so it seems if you were missing a ground,, you would atleast have half the lights.
Had to replace my head light switch the other day. The first we we bought from Orileys was bad, and they didnt stock them. wait for the first one... wait for the second
Old Jan 23, 2012 | 05:18 PM
Engine: 305 v8 h.o.
ok thanks, my dad is an electrician and after hunting season gets over we are gonna get working on this pretty heavy
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
