I need heat, Blower motor not working
I just bought an 85 trans am, and the blower motor does not work at all. No matter where you turn the controls nothing. I;m not to good at electronics, could it just be the motor? or something else... Thanks
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Why Doesn’t This Blower Add Horsepower ?
The blower motor is located on the right side firewall behind a roundish housing.
You will see a 12 AWG purple wire going to it.
That is the place you will apply power to see if the blower works.
Happy Racing!
I Didn’t Jump The Start, The Flagman Was Late
Happy Racing!
Re: Why Doesn’t This Blower Add Horsepower ?
Okay Thanks, anyway just cleaned all the connection better and it works on all speeds. Thanks, the vents dont work but that has to do with vaccuum right?
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: I need heat, Blower motor not working
Yes,..... the air "mode" is controlled by vacuum on the AC equipped 82-89 cars. AC/Delete cars used a cable to control air delivery during those years. From 90-92 AC AND AC/Delete cars used vacuum controls.
Inside the engine bay the AC/heater harness will have 1 hard plastic vacuum line sticking out of it. Start by checking that this vacuum line is connected to a vacuum port on the intake or Carb. If it is,..... close the hood and get ready; the next step is to start checking the vacuum lines under the dash !
1992rs/ss
Jan 31, 2025 05:10 PM
Street Lethal
Aug 13, 2015 08:28 PM
