Blower motor issue
Old Feb 2, 2012 | 05:52 PM
RachaelRider16's Avatar
Car: 1989 Camaro RS
Engine: 5.0 ltr. 305 TBI stock with holes d
Transmission: T-5 five speed
Blower motor issue
After 4 years of "rest" I finally got my '92 Trans Am running again. When it got parked the heat and A/C worked fine. Now the blower motor won't even turn on. Neither will the A/C compressor. I have run a jumper wire straight from the motor to the battery and also one to a ground and still nothing. Are there any common problems that occur from long periods of inactivity? Any advice would be greatly appreciated. Also when I move the selector I can hear air doing something, so I think the vacuum part of it is ok.
Old Feb 2, 2012 | 09:43 PM
Seafarer12's Avatar
Car: 92 GMC K2500 LD
Engine: 350 TBI with some mods
Transmission: NV4500
Re: Blower motor issue
I imagine you have a some stuck bushings or brushes on the blower motor. You could pull the motor and try to get them freed up, thats the easy one. As far as the compressor what does it do when you turn the ac on?
Old Feb 3, 2012 | 07:06 AM
Car: 1989 Camaro RS
Nothing. It doesn't engage, it doesn't even click or anything. I'll try to get the motor off today and take a look at it
Old Feb 3, 2012 | 06:40 PM
Seafarer12's Avatar
Once you got the fan freed up I would check the ac clutch fuse. I would also make sure you have freon in it. If you don't have a set of gauges you can use your ohm meter and check the low pressure switch. It is on the low pressure side (the big line) on or around the accumulator ( the big silver can in the low pressure line). If it is open it won't let your clutch engauge.If it is good then with the car running I would pull the plug to the clutch and see If you are getting 12 volts to it through the plug. If you are I would then use an ohm meter to make sure the coil in your clutch isn't open. If the low pressure switch is open then you need to get a set of gauges from someone to check your pressures. Once you check all that we can go from their.
Old Feb 21, 2012 | 03:06 PM
Car: 1989 Camaro RS
I got it working. turns out, there is some kind of plastic gear or something inside the selector box that had separated a little. I squeezed it back together and the air stopped hissing, then the A/C and everything started working. Thanks for the replies
Frozer!!!
Jan 19, 2024 04:55 PM
Wesly_66
Aug 26, 2015 09:55 PM
86White_T/A305
Aug 17, 2015 12:16 AM
mhatfield 14
Aug 15, 2015 10:47 AM
Street Lethal
Aug 13, 2015 08:28 PM
