Battery Arching
Old Feb 2, 2012 | 07:01 PM
LoudTransAm's Avatar
Car: 1987 Trans Am GTA
Engine: TPI 350
Axle/Gears: 9 bolt From An Aussie
Battery Arching
So I leave work today and for about 1 second into accelerating the car starts to hesitate and then dies completely. Well I pull off the road (which sucked without power brakes and steering!) I pop the hood tp find the negative ground cable had come off and had melted the terminal. I try to see if I could get it back in and see if the car would start and it was a fireworks show! Tested the battery and it was showing 12.6 volts and holding. Well gpa showed up with a battery and it too started arching when we attached the ground. Checked all fuses and non were blown. I am stumped. I figure its an open somewhere but wouldnt know where to start with the EFI system! Anyone have advice or previous symptoms?!
Old Feb 2, 2012 | 09:37 PM
Seafarer12's Avatar
Car: 92 GMC K2500 LD
Engine: 350 TBI with some mods
Transmission: NV4500
Re: Battery Arching
Did yout starter solenoid hang up and keep driving your starter motor? That is about the only thing on your car that would pull enough amps and not have any over current protection to melt lead along with causing massive arcing.
Old Feb 8, 2012 | 06:25 PM
hilltop530's Avatar
Car: 1987 Iroc Z28 Camaro
Engine: 5.7 TPI
Re: Battery Arching
hook the neg cable to the battery first then the positive. if you still have major sparks, this means you certainly have a short. Check the back of the alternator at the main positive cable, check your starter motor cables, check all ground straps and connections.
Old Feb 8, 2012 | 06:56 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Re: Battery Arching
As you aren't blowing fuses or fusible links, sounds like the pos batt cable to starter/alt, or alt terminal is shorting to ground somewhere.
Falcon50
Aug 22, 2020 03:26 PM
3rd gen money
Oct 11, 2019 09:57 PM
RS Reaper
Oct 17, 2018 07:52 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
drumstixer
Sep 29, 2015 03:02 PM
