HELP NO REVERSE LIGHTS!!!!
Old Feb 11, 2012 | 01:16 AM
86_irocz-28's Avatar
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
I have an 86 irocz reverse lights wont work but for a split second when i go to put it in reverse i thought maybe the bulbs were getting close to burning out so i replaced them same problem exist. Anybody know what to do?
Old Feb 11, 2012 | 01:43 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: HELP NO REVERSE LIGHTS!!!!
Your neutral safety switch needs to be adjusted. It's attached to the side of the shift mechanism.
Old Feb 11, 2012 | 01:54 AM
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Not looking at it right now so how do i adjust it?
Old Feb 11, 2012 | 01:58 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Take off the shift plate and it'll be obvious.
Old Feb 11, 2012 | 02:05 AM
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Alrite thanks I'll take a look in the morning thanks
Old Feb 11, 2012 | 04:58 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
attached to side of shifter mech ,has 6 wire connector going to it
Old Feb 11, 2012 | 12:16 PM
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
stupid question but how do i adjust it?
Old Feb 12, 2012 | 07:46 PM
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Old Feb 12, 2012 | 08:33 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Loosen the two or three screws that fasten the switch to the shifter and rotate the switch fore/aft until the back-up lights stay on. Before you button it up, confirm that the engine cranks only in P and N and not in any other range.
Old Feb 12, 2012 | 10:14 PM
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Heres what mine looks like. Im guessing your talking bout the silver part that attaches the plug to the the rest of the shifter assembly?
(The yellow wires and black and red are ran for switches so ignore those)
Old Feb 12, 2012 | 11:01 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Old Feb 12, 2012 | 11:46 PM
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
And god said let there be light!!!! thanks paulo you saved me a huge headache and having to waste money taken it in to be looked at
Old Apr 8, 2012 | 03:19 PM
Cadaver Puncher's Avatar
Car: 92 rs daily driver work in progress
Engine: 3.1 , 204/214 cam
Transmission: 700 r-4, b& m megashifter
Axle/Gears: I want a posi with rear discs
I got my camaro thru auto repairables. The driver's side took a hard hit replaced the ¼ and the door already. But the previous owner put in a B&M ratchet shifter. The reverse ( or back-up lights ) aren't working. I see a blue and a green wire that was clipped. Could one of these be wired to a switch?
I like the idea of it being hard to shift. If I ever get car-jacked, I'd just put it in park and lmao.
On another plus side, my wife can't drive it either.
Old Apr 9, 2012 | 04:00 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Get Back !
Yes the blue and green wires are connected to the reverse light switch on the shifter.
Connect those to the
blue and green wires which you should find under the console.
Happy Racing!
Slamming The Wall Is Not The Neatest Way To Remove An Engine
Old Sep 5, 2012 | 08:54 AM
skip91's Avatar
Car: '91 RS, '64 C10 Stepside
Engine: 305 TBI, '00 5.3
Transmission: Manual, Automatic
Axle/Gears: 4th Gen with 3.42, 4.10
Is the same switch applicable for a '91 RS 5-speed? I'm having the same issue with intermitent/no reverse lights.
Old Sep 5, 2012 | 09:20 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Probably not. The manual transmission probably uses another switch. Most likely it's plugged into the transmission.
Perhaps someone else can confirm this for you.
Old Sep 5, 2012 | 10:29 AM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
I think that is correct, I am pretty sure it is in the tranmission
Old Sep 7, 2012 | 08:34 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Yes, left/driver side of the transmission body has a two-prong plug, with a dark-blue wire and a light-green wire. The dark-blue wire should have power with key-on, the light-green wire sends the power when it is activated by the reverse gear in the transmission.
Hope this helps.
Lou
Old Jan 30, 2015 | 06:43 PM
morries's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
I have a 92 camaro t5 and when i shift into reverse the lights come on but when i release the clutch and start moving the lights flicker on and off at different intervals. Any help would be much appreciated
Old Feb 17, 2015 | 04:29 PM
NINÅ's Avatar
Transmission: 765R4
Get Back !
It sounds like the switch needs adjustment.
You can monitor the by connecting a 12volt ready LED across it and mounting it in the cockpit to prove or disprove the switch is the problem.
Happy Racing !
We Keep The Air Wrench Shiny So It Looks Good When We Throw It Across The Pit Box
Old Aug 23, 2019 | 08:53 PM
Musicman82's Avatar
Car: 1984 Trans Am
Engine: 305 H.O.
Transmission: 5 speed manual
im having the same issue on a 84 trans am wiith a T5, how could i fix it?
Old Sep 2, 2019 | 01:34 PM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
https://www.holley.com/products/driv...SABEgJe4vD_BwE you need this that mounts to the shifter and acouple screws
Old Sep 2, 2019 | 03:25 PM
The T-5 RLS is on the side of the transmission. Driver's side, rear of the case, right in front of where the extension housing bolts to it. Very eeeeeezy to replace. Might need tightening. Might just be the connector loose or something like that.
86IROC_stick
Jul 16, 2014 01:01 AM
BlueIrocZ
Oct 19, 2011 01:56 PM
bulletboy29
Aug 27, 2004 12:35 AM
Flyersman29
Jul 10, 2003 10:17 AM
ip305
Jan 27, 2002 05:58 AM
