Gauge Cluster Lighting Issue
Old Feb 19, 2012 | 02:16 PM
John91VertZ28's Avatar
Car: 1991 Convertible Z28
I have a 1991 Camaro Z28 convertible. The problem I'm having is everytime I turn the lights on, the lights on the tach side will go dim and the lights for the turn signal and high beam will glow.
My fix (for now) is using the palm of my right hand, I hit the dash pad... then the tach is nice and bright and the turn signal and high beam lights go off, but only temporarily. It will happen over and over as I am driving, it happens so often to the point that the palm of my hand starts going numb.
I know it is a ground issue. I am just hoping that someone out there has had the same problem and has found the real fix. So Please if you have had this problem and found maybe a ground that commonly gets loose, please let me know.
Old Feb 24, 2012 | 12:38 PM
Annihilated911's Avatar
Car: 91 z28
Engine: 5.7 350 TPI '91
Transmission: World class T-5
Axle/Gears: Stock ??
Re: Gauge Cluster Lighting Issue
Im havin the same problem with a 91z28. My blinkers stay illuminated but when i hit the turn signal my blinkers dont work at all =\
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
tnrednneck
Aug 13, 2015 08:57 AM
ChevyZ71
Aug 13, 2015 07:30 AM
