89 camaro iroc z eletrical problems!!!!!!
Old Feb 28, 2012 | 05:24 PM
dee9283's Avatar
Car: 89 Iroc Z 350 TPI
Engine: L98 350
So one day me and my dad were charging my dead batt up and he touched the positive post to the positive post of the batt and a something sparked which probably shorted something out but in the end I have no headlights, foglights, turn signals, interior lights, brake lights, or tail lights. The only lights I have are reverse lights for some odd reason. I need help fast could this be a relay cause I checked all my fuses and everything was working perfectly expect turn signals up til that day. Thank You
Old Mar 1, 2012 | 07:03 AM
Dreader's Avatar
Car: 1992 camaro rs 25th anv
Engine: 305 5.0
Transmission: 5speed not sure what kind
Re: 89 camaro iroc z eletrical problems!!!!!!
check your fuses? start out with the simple stuff first
Old Mar 1, 2012 | 01:48 PM
dee9283's Avatar
Engine: L98 350
yea that was the first thing i did but no luck. The day he touched the post on the batt something started smoking right after a small spark
Old Mar 2, 2012 | 04:33 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Hey Dad, . . . . . . . . . . . . I’m MAD !!!!!!
It sounds like you popped one or two Fusible Links located near the starter.
Fusible Links look like a one inch plastic rod in line with the wire.
Using a voltmeter or test light
(the type for testing for voltage, not a continuity tester) probe one end, then the other of each Link to check.
Happy Racing!
Spin Me This Week . . . I’ll Spin You Next Week
Old Mar 13, 2012 | 04:56 PM
dee9283's Avatar
Engine: L98 350
ok do u think u can send me a pic of wat it looks like just to make sure im testing the right thing?
Old Mar 13, 2012 | 05:03 PM
dee9283's Avatar
Engine: L98 350
and if they are bad is there any way to change them out??
Old Mar 14, 2012 | 06:13 PM
NINÅ's Avatar
Transmission: 765R4
Here’s a typical fusible link.
However replacements can look like a plain piece of wire.
To test a link you can use a test light
(the type for testing for voltage, not a continuity tester) to probe each side.
The fusible links should power on both sides at all times.
You can replace links by splicing in new ones with splices and a crimper.
Happy Racing!
I’ll Bump You Once To Move You Over, Next Time I’ll Spin You
Linson
Aug 21, 2015 02:12 PM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
mustangman65_79
Aug 11, 2015 03:17 PM
Fronzizzle
Aug 9, 2015 01:15 PM
Rustyweb7
Aug 9, 2015 03:05 AM
