Digital Speedometer Help
Old Mar 14, 2012 | 12:25 AM
Torchred87T/A's Avatar
Car: 95 C1500, 91 & 92 Camaros
I have a 1987 Trans Am with the digital dash, it was originally305 TPI or TBI with T-5, cant remember off the top of my head, but it was switched to a carb before the junkyard I pulled it out of got it, and it ran fine, tranny was messed up though, anyways I am putting a 350/TH350 combo in it and I'm wondering if the speedo with hook directly to the TH350 or will I need some type of adapter for it to work.
I've googled it about 100 different ways and searched this forum the last hour, and all the post I've seen never come to a conclusion, if you do, or do not need an adapter
Old Mar 14, 2012 | 12:28 PM
Patrick Day's Avatar
Re: Digital Speedometer Help
No the speedometer will not hook directly up to the TH350 , The speedo is electronicitly controlled and run by wires from your tranny to your speedometer and your computer. And I have no idea if they even have an adapter for this switch.
Old Mar 14, 2012 | 12:33 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
If you have a cable drive with the optical sensor on the back of the ip it will hook up. If it was a vss than get a 2k ppm vss.
http://tpiparts.net/inc/sdetail/7586
Old Mar 14, 2012 | 02:23 PM
Hey sorry for being illiterate but what does vss mean? I know the speedo was working with the carb setup that was on it and its going back carbed so I guess I'm out of luck...
Old Mar 14, 2012 | 05:55 PM
Sonny_T's Avatar
Car: Transam, 85
Engine: 305 HO, 4bbl Carb, G Engine
Transmission: 5 Speed
VSS: Vehicle Speed Sensor. It is installed on transmission. Wires runs from VSS to the ECM. Its job is to 'sense' speed and provide information to ECM. ECM collects information from various sources and VSS is one of them. Based on all info, ECM sends controlling signal to the 'fuel/air' system for engine performance. Depending on vehicle, this performance may range from 'engine won't start' to 'best run'. For a 'non-carburated + Auto trans' VSS certainly play a major role.
Old Mar 14, 2012 | 06:45 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Simple .
Look under the car at drv side rear of trans location
If you have a speedo cable there; it will connect to the TH350.
If there is a 2 wire plug with yellow and purple wires ,you need the cable driven VSS unit to supply the signal to the dash
Old Mar 14, 2012 | 06:46 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
delete
Old Mar 15, 2012 | 02:09 AM
As soon as I check for Rattlers under it I'll look, its sitting without drivetrain at the moment but it as soon as i buy a torque converter for it, and paint the engine, its gonna run, I hope. Getting my permit on Friday and this Third Gen will be the car that teaches me how to drive , 1/4 miles and a few twistys lie ahead
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
sheachopper
Jul 31, 2019 11:27 AM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Eric-86sc
Sep 28, 2015 11:37 AM
