HELP HEI distributer swap
Old Mar 1, 2012 | 11:45 AM
KlemmNation's Avatar
Car: 85 camaro z28
I swapped in a new hei style distributer and i have to hook a 12V source to it. What is the best place to splice into as i am not a wiring guru. any pictures would be a huge help.
Old Mar 1, 2012 | 11:53 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: HELP HEI distributer swap
Pink wire from the old distributor.
Old Mar 1, 2012 | 11:56 AM
Car: 85 camaro z28
the pink wire was only 8 volts.
Old Mar 1, 2012 | 12:00 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Then something is wrong with your car.
Old Mar 1, 2012 | 12:01 PM
Car: 85 camaro z28
also the new hei came with a vacuum advance option should i hook that up as well or leave it off as my last distrib didnt have vacuum advance
Old Mar 1, 2012 | 12:05 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
if you only have 8 volts at the hei power wire you need first need to check your surface voltage at you battery and then check the connections at the ignition switch. you failed to mention is this on a ccc, tbi or tpi car should like you bought the wrong distributor.
Old Mar 1, 2012 | 12:07 PM
Car: 85 camaro z28
this is on the ccc i am putting the mechanicla carb on over the weekend
Old Mar 1, 2012 | 12:12 PM
Engine: Lb9
Transmission: M20
fix your power issue to the coil and hook the vacuum advance to a ported vacuum port on your new carb.
Old Mar 1, 2012 | 12:45 PM
BadKoopa's Avatar
On my 305 with HEI distributor I use the thick pink wire (think it's 12 gauge?) which is 12volt that leads from the wiring block on firewall along with all the other wires for the lights and what not. I am not an electronics expert but I would assume you could find another 12 volt source from fuse block that is hot when ignition switch is both in the on position and starting position. On my car I have an ignition fuse with additional link in my fuse block that is 12volt hot when ignition is in the on position that I use to link up to my electric choke on carb, but I don't think it runs hot when ignition is in starting position which is what you'd want for the distributor since it needs constant power after switch is started and back to on position. I'm sure an expert will jump in on this soon with a good response, but one question that comes to my mind is that if you do end up finding another 12 volt source that something else is using the distributor might put a voltage strain on that line causing problems for whatever else is using it? not sure.
midge54
Jan 29, 2017 07:00 PM
db057
Sep 4, 2015 07:57 AM
pimprs
Aug 24, 2015 11:20 PM
theurge
Aug 21, 2015 12:46 PM
midias
Aug 15, 2015 05:07 PM
