Wiring up Hella Fogs to a light on/off switch on a 87 TA
Old Mar 9, 2012 | 03:52 PM
mrrman's Avatar
I have some Hella Fogs that I have installed in my car and would like to know if I can use this switch with a relay. The switch has 6 blades on it so how do I determine which blades to use. I want to use this switch since it matches my interior switches whereas the 3 prong switch that came with the Hella Fogs doesnt match at all. I may have a relay that came with the Hella Fogs, I am not sure. The Hella fogs have 3 wires coming from it.
Old Mar 19, 2012 | 04:14 PM
NINĊ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Show Me The Way !!
The way to determine which terminals to use: connect one lead of an ohmmeter to one of the 6 fingers on the switch, and use the other lead to probe the other fingers as you operate the switch.
When you have 0Ω you have found the fingers you need.
If you have no luck with the first test, move the lead you first connected to one of the fingers and move it down one, then repeat the test.
Happy Racing!
I Hit The Water Barrels Because My Car Was Dirty
Old Mar 19, 2012 | 07:51 PM
mrrman's Avatar
Re: Wiring up Hella Fogs to a light on/off switch on a 87 TA
thanks for the reply
Old Mar 23, 2012 | 09:00 AM
mrrman's Avatar
Should I install a relay between the fogs and switch or is a straight connection okay?
Old Mar 26, 2012 | 03:45 PM
NINĊ's Avatar
Transmission: 765R4
Show Me The Way !!
Use a relay.
Happy Racing!
I Don’t Mind Wreckin’ On The Track, No Paperwork To Fill Out
BRoss99
Aug 10, 2025 05:08 PM
Brcharrelson
Aug 26, 2015 07:47 PM
tnrednneck
Aug 13, 2015 08:57 AM
mustangman65_79
Aug 12, 2015 06:39 AM
Omega
Aug 10, 2015 12:46 PM
