stock shift light
Old Mar 16, 2012 | 02:27 PM
Dezined's Avatar
Car: 91 Camaro RS - B4C option
Engine: L98 5.7l V8
Transmission: 4 speed auto
stock shift light
I noticed the other day that my car has the spot for the stock upshift light. When i dug in my shop manual, I could see the circuit for the light, but the manual doesn't say where the wire comes from that activates it.
Does anyone know how the light behaves? is it set to come on at a certain rpm in the ecu? How can I test the light? Mine doesn't come on, which could just be a blown bulb, I haven't dug in the cluster yet, but being as I'd like to have a shift light, if using the stock one is viable, I'd like to do that.
Old Mar 16, 2012 | 03:57 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: stock shift light
The ECM will turn it on any time it thinks you're in too low a gear. Very rarely will it be when you also think you're in too low a gear.
Old Mar 16, 2012 | 04:08 PM
Dezined's Avatar
Engine: L98 5.7l V8
Oh hell. So it won't work the way I thought it would. Do they make some type of control module that I can run to the light and turn it into a normal shift light?
Old Mar 16, 2012 | 04:11 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You'd just need a regular RPM-activated switch.
Old Mar 16, 2012 | 04:12 PM
Dezined's Avatar
Engine: L98 5.7l V8
Excellent, that sets me on a good path. Thank you sir!
Old Mar 16, 2012 | 06:33 PM
mjwadams's Avatar
Car: 92 RS
Engine: L03 with Holley Sniper EFI, headers
Transmission: T-5, hurst billet shifter
Axle/Gears: 3.08 posi
The light is for maximizing gas mileage, not performance. At today's gas prices, that is pretty useful to have if you can get it to work. Have the real shift light for your launches but use the other one when you are traffic.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
tnrednneck
Aug 13, 2015 08:57 AM
dhonda200
Aug 11, 2015 11:50 PM
Omega
Aug 10, 2015 12:46 PM
