fuse box connectors.
Old Apr 6, 2012 | 11:27 PM
z28z34man's Avatar
Car: 1984 z28 camaro / 2019 accord sport
Are the little connectors inside the fuse box replaceable. I would like to repurpose a few unused spots for other things, and I would like the install as clean as possible with as few as splices as I can get.
Old Apr 9, 2012 | 01:16 AM
88 TA GTA's Avatar
Car: MSD Dist., Crane Hi 6 ignition
Engine: 350 - 50 over, S/R Torquer Heads
Transmission: T56 - Originally a 700R4
Axle/Gears: 9 bolt posi with 370
Re: fuse box connectors.
I have used the single empty spots to run other items. Some have power with key at ACC others have power in RUN position. You still need to use a properly rated in-line fuse to protect that circuit.
Old Apr 10, 2012 | 09:03 AM
z28z34man's Avatar
Where you able to get the oem style connectors I just plan on using the slot for radio ecm and other things I have removed long ago
Old Apr 10, 2012 | 02:00 PM
88 TA GTA's Avatar
I used Male Disconnects Solderless Terminals. these slide right in the slot the fuse normally goes. Just splice one on the end of your wire with fuse holder with correct amp fuse and run to whatever requires power.
$750 L98
Feb 1, 2025 02:25 PM
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
tattmann
Sep 27, 2015 05:20 PM
Dragonsys
Sep 25, 2015 03:51 PM
lanceflame44
Sep 25, 2015 12:28 PM
