Key Off: RPM's won't go down.!
Old Apr 16, 2012 | 04:51 PM
SpecialEditon84's Avatar
Car: 1984 Pontiac Firebird S/E
Engine: Pontiac 2.8 L V6
Transmission: Automatic 4spd
Axle/Gears: Stock
Ok. When I have my engine running say 1000 RPM's. It will idle yah know, whatever. And then when I turn my key off the RPM gauge dosen't go down to 0. It stays at whatever RPM's it was at when I turned the key off. Until, I turn the key back to ready position the RPM's stay up. When I put it to ready position they go back down to 0. Any thoughts?
https://www.youtube.com/watch?v=tcZC...Qp0Vh9jdmi4%3D
The video I posted was for my buddy Mark. He can't diagnose the problem. Ignore the other stuff that's in the video just watch my gauges.
Old Apr 16, 2012 | 05:04 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Re: Key Off: RPM's won't go down.!
Mine does the same, along with the other gauges. It's common I think
Old Apr 16, 2012 | 05:06 PM
Axle/Gears: Stock
But, it dosent do that with other ones. I don't know why?!! I wanna fix it!! IT DRIVES MY FLUCKIN LUTS!
Old Apr 16, 2012 | 05:44 PM
Engine: L31 350
It bugs me to but you get use to it
Axle/Gears: Stock
GOD I hate it. haha like when I park it in the drive way I turn the key again and turn it back to 0 ahah just to make me happy when I get back in it to go to work lmfao
Old Apr 16, 2012 | 05:50 PM
SDTransAM's Avatar
Car: '83 z/28
Axle/Gears: Stock?
It's because when you turn the key off, there is no power going to the gauges, so they just sit where they were last at with power on.
You could put new gauges in that arent old as **** and probably worn out, or you can just deal with it, haha.
Old Apr 16, 2012 | 05:55 PM
Axle/Gears: Stock
can i run a hot line to it to make it turn off?
Old Apr 16, 2012 | 06:04 PM
SDTransAM's Avatar
Car: '83 z/28
Axle/Gears: Stock?
Why not just turn the engine off, turn the key back on to reset the gauges, then turn the key back off?
Or you could just run a kill switch for the engine so that you can leave the key on and kill the engine so you can watch your gauge go back down to 0
Old Apr 16, 2012 | 06:07 PM
Axle/Gears: Stock
Wouldn't that hurt my engine? Cuz I have a engine killswitch.
Old Apr 16, 2012 | 06:13 PM
SDTransAM's Avatar
Car: '83 z/28
Axle/Gears: Stock?
How do you think the engine turns off now? You cut out the ignition, the engine turns off. Whether you use a kill switch, or the ignition switch it doesn't matter.
Old Apr 16, 2012 | 06:15 PM
Axle/Gears: Stock
I have an old chapman lock on it. its great haha. But, like my voltage gauge and all the other ones go back down to 0. Why not my RPMs?
Old Apr 16, 2012 | 11:37 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Because that's not how it works.
Old Apr 17, 2012 | 03:58 AM
jeff_blake's Avatar
Car: 86 Iroc + 83 Firebird
Engine: Iroc 305 TPI, Firebird 305 4bbl
Transmission: 700r4 in both.
Axle/Gears: Iroc 3.27 Firebird 3.23
mine do too, turn the car off, then key in the on position and it goes down, turn it back off and its fine. i usually just leave it though
Old Apr 17, 2012 | 04:00 AM
jeff_blake's Avatar
guess i should have watched the video first. urs does the same thing as mine
Old Apr 20, 2012 | 09:25 PM
Axle/Gears: Stock
Its really weird because then the RPM gauge goes back up a little to like 500 RPM's.
Old Apr 20, 2012 | 09:26 PM
Axle/Gears: Stock
do yours do that too?
Old May 5, 2012 | 01:06 PM
Axle/Gears: Stock
So there is nothing I can do to fix this?
Old May 5, 2012 | 01:10 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You can't fix it because it's not broken.
Old May 5, 2012 | 02:03 PM
Axle/Gears: Stock
Why the fluck would GM do that? Just to annoy people?
Old May 5, 2012 | 03:06 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Because it was inexpensive to build the movement that way and nobody has any reason to care what the gauge reads when the car is off.
Old May 5, 2012 | 06:15 PM
Axle/Gears: Stock
I do because it looks like **** and it looks broken lol. I mean can i do ANYTHING to make it go down to 0 when I turn the key off?
Old May 6, 2012 | 12:02 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Nope
Old May 6, 2012 | 07:38 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
You could get a 12volt timer say that would stay on 5 seconds after power was cut off and run that power wire to gauges.
Old Jul 17, 2012 | 10:17 AM
Axle/Gears: Stock
woah! I AGREE! I did that and it works awesome. i set it 1 second after and it goes right down after i turn the key off! THANKS BUD!
Old Jul 17, 2012 | 04:56 PM
Edwardgp's Avatar
Engine: 454-350
You are quite welcome Special glad it solved your problem, also thanks for letting me know it worked.
eightsixseven
Dec 16, 2024 01:50 PM
Logan Bryant
Aug 27, 2015 11:52 AM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
djmarch
Aug 19, 2015 12:07 PM
