91 hatch pull down ?
Old Apr 18, 2012 | 03:05 PM
mintc's Avatar
ok heres my problem my hatch motor wasnt pulling my hatch down, i searched this for with no results of my problem. i replaced the hatch pull down motor and relay i got power to the motor and when i flip the switch down the motor will kick on and stop after a sec or to but when i flip the switch up nothing. is the motor reversible? runs one way with the switch up and the other way with the switch down? could it be my motor? i put a test light on the switch and flipped the switch up and down it does reverse the polarity but does nothing when i put the switch back on the motor
Old Apr 23, 2012 | 05:45 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Turn Of Events
Yes the motor is reversible.
If it’s the original the brushes probably need to be replaced.
If you can gain access to the commutator and turn it when it’s supposed to be turning, and turning it causes the motor to run, replace the brushes.
Happy Racing!
If Your Communications Antenna Is Not Shaking At Idle, Your Cam Is Too Mild
Old Apr 23, 2012 | 05:46 PM
GreenCamaro13's Avatar
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
Axle/Gears: 5 Speed Manual
Re: 91 hatch pull down ?
Do you have anything in the way? such as a speaker box in the back?
Old Apr 23, 2012 | 06:08 PM
djdsails's Avatar
Car: 92 camaro RS
Engine: Moded 350 engine
Transmission: 5 speed
make sure every part in the system is working correctly. here is a wiring diagram
Attached Thumbnails 91 hatch pull down ?-diagram_1992_hatch_pull_down_release.jpg
Old Apr 23, 2012 | 06:09 PM
djdsails's Avatar
Car: 92 camaro RS
my problem was the switch actuator, i lubed it up and flipped it many times and it came back to life
Old Oct 15, 2012 | 02:58 PM
iluvgyrlz's Avatar
Car: 1991 Camaro RS
Engine: V8 350
Transmission: 5 Speed Manual
I've been trying get my actuator back on trunk latch I replaced properly and feel so defeated. Can you let me know how you got yours back on properly? When I turn the key, it won't unlock the lock, but the switch inside works flawlessly.
83 Crossfire TA
Jan 3, 2016 01:26 PM
90formulaVortec
Exterior Parts Wanted
Sep 7, 2015 07:17 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
scottmoyer
Sep 7, 2015 07:06 PM
90formulaVortec
Sep 7, 2015 06:54 PM
