hatch switch turns engine??? (Fixed)
Old Apr 25, 2012 | 02:25 AM
thatoneguy5x's Avatar
Car: camaro
Engine: 3.1
Transmission: auto
so i got a V6 92 camaro rs about a month ago. when i got it the dome,side mirrors, power locks, and hatch switch wouldnt work. changed the fuse and all but the locks would work. id hear a clicking but nothing would happen. not concerned about that at the moment. but when i tried the hatch switch it started turning the motor like trying to turn my car on. im no expert or anything like that but im pretty sure that isnt supposed to be happening. oh and the hatch wouldnt open. obviously.... i really wouldnt mind just using the key to open the hatch BUT key wont open it. key only seems to work on the driver door and ignition.
the pull down motor works cause i poped it open with a flat head from the inside. my guess is some1 put a wire where it shouldnt go or something. tried following the wire with no luck. hoping som1 here can help me out a bit more. any advise would be greatly appreciated
Old Apr 25, 2012 | 08:53 PM
Car: camaro
Engine: 3.1
Transmission: auto
Re: hatch switch turns engine???
anyone???
Old Apr 25, 2012 | 09:03 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Assume you have an auto trans. I have read a couple of threads similar with this question. Not sure if the 92 hatch switch circuit is the same as my 86 circuit (attached below), but here is my theory.
Looks like for cheapness, GM has the ground for the hatch release relay piggy-backed to the top of the park/neutral lock-out switch and thru the start solenoid, so that the hatch can only be release in p/n.
In effect, this also allows the hatch release switch to supply +12v to the start solenoid via the yellow wire 3 and the p/n switch, exactly the same way as the ign switch does in the bulb test/crank position.
The only difference is the resistance of the release relay coil, which must limit the current enough, so that the release switch is incapable of operating the start solenoid.
So something has changed in this balancing act. The release relay coil has decreased resistance and is passing more current, or the start solenoid is requiring less current to operate for some reason. Most likely the release relay coil has a full or partial short.
Old Apr 25, 2012 | 11:22 PM
Car: camaro
Engine: 3.1
Transmission: auto
is there any way to bypass this? maybe cutting the yellow wire? I'm not gonna jump right in and do this, I wanna find some more info on this first. I've been searching the forum for a couple days now with no luck
Old Apr 26, 2012 | 12:12 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Like I said, this is just my rough theory looking at my 86 circuit which may not completely apply to you.
I'm thinking your vats should be in the mix there too somewhere, locking out the starter and preventing the starter from operating, obviously it isn't. Sorry don't have a 92 vats circuit.
Find the relay, and measure the coil with a DMM (should be maybe 30-50 ohms at a rough guess) or replace with a cheap one from the jy. Don't just cut the yellow wire (if applicable), or your hatch button won't ever release the hatch.
Sorry but I don't know where the relay's stock location is, esp in the 92. In my 86 it's in a socket that just hangs out of the interior loom, but all my internal wiring was re-routed in my rhd swap by a PO.
Does the hatch button pop the hatch like it should, as well as crank the engine?
Old Apr 26, 2012 | 12:42 AM
Car: camaro
Engine: 3.1
Transmission: auto
no it doesn't actually. has me thinking the wiring isn't even goin to the pull down motor. or maybe there is a cut wire somewhere, I took I'm all my center console and kick boards I really didn't want to rip out the carpet to follow the wiring. at the moment I don't have anything to test currents with, i'll have to take some more time tryin to figure something out. i really have no electrical skills
Old Apr 26, 2012 | 01:24 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
If the 86 circuit is applicable, bet it's a shorted relay coil. It would crank the engine and fail to pop the hatch, even with all the factory wiring intact.
If you don't have a multimeter or the know-how to use it to troubleshoot at this time, best you can do is just swap the relay out.
Old Apr 26, 2012 | 01:30 AM
Car: camaro
Engine: 3.1
Transmission: auto
thanks for your help, I'm gonna look into it a bit more before doin anything. the manual wasn't much help to me
Old Apr 26, 2012 | 03:02 AM
Car: camaro
Engine: 3.1
Transmission: auto
ok so I think I know what shorted it out. my ttop leaks right onto the hatch switch. would I have to switch out the relay or would a new switch possibly help
Old Apr 27, 2012 | 06:27 AM
DrewsCam's Avatar
Car: 1991 Z28
Engine: 355 TPI
Axle/Gears: 9 bolt disc / 3:27
If your switch is shorting out replacing it will deginately not hurt
Old Apr 27, 2012 | 01:42 PM
Car: camaro
Engine: 3.1
Transmission: auto
is there any other relay i should try changing? i figure im goin to the junkyard today anyway. might as well pickup probable causes parts
Old May 15, 2012 | 03:50 AM
Car: camaro
Engine: 3.1
Transmission: auto
Re: hatch switch turns engine??? (fixed)
so I guess I had a bad ground or something, I just cut the green wire and grounded it, now the hatch release switch works just fine and the engine doesn't crank anymore when I try to open the hatch
Spyder_TheGamer
Dec 25, 2015 05:07 PM
86IROC112
Aug 17, 2015 02:00 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
ZsTransAm
Aug 11, 2015 07:30 PM
Fronzizzle
Aug 9, 2015 01:15 PM
