interior lights cigarette lighter and door locks wont work?
Old Apr 26, 2012 | 05:44 PM
zmitty91's Avatar
Car: 89 camaro rs
Engine: 305 tbi
Transmission: 700 r 4
89 camaro rs 305. Interior lights cigarette lighter and door locks don't work I pulled all fuses and tested them on meter they are all good. I heard it could be cigarette lighter but its not blowing any fuses could that still be problem? Help please. Any suggestions?
Old Apr 26, 2012 | 05:49 PM
shortyskater's Avatar
Car: 1987 Chevy Camaro Iroc-Z
Engine: just an empty hole. LS1 coming soon
Transmission: nothing there either. T-56 soon!
Axle/Gears: soon Moser 9 bolt
Re: interior lights cigarette lighter and door locks wont work?
Do the lights and locks work when the cigarette lighter is out? Usually it is the culprit since with old age and time it shorts itself out.
Old Apr 28, 2012 | 06:30 PM
zmitty91's Avatar
Car: 89 camaro rs
Engine: 305 tbi
No I took out the cigarette lighter completely and disconnected it checked all fuses again and they are still good but no interior. Lights except for dash panel and my radio is aftermarket so that works. But no overhead light or lights from rearview mirror I do have a small light that is hanging from the left side underdash out of center console that is on but idk why the others don't work. Any suggestions?
Old Apr 28, 2012 | 06:48 PM
Probably a stupid question but, are the bulbs good?? Only other thing I can think of is a bad ground maybe??
Old Apr 28, 2012 | 07:53 PM
blackjack12982's Avatar
Subscribed, mine is the absolute same way.
Old Apr 28, 2012 | 08:07 PM
zmitty91's Avatar
Car: 89 camaro rs
Engine: 305 tbi
Yep prolly a wiring issue the guy who owned it before me f,d the wiring all up. So I'm buying an aftermarket fuse block and running everything that does not work to that one. So I'll just have two fuse blocks and I'll just label the second one so when I sell it whoever buys it will know how its wired.
Old Apr 29, 2012 | 12:54 AM
02 camaro's Avatar
Car: 1987 Pontiac Firebird Formula
Engine: 305 T.P.I V-8
Transmission: M5
Axle/Gears: 372's
Before you do that I know it sounds stupid make sure there IS a fuse in the VSS spot. Mine did the same thing i just overlooked there not being a fuse in the VSS spot. Its a 20Amp BTW.
Old Apr 30, 2012 | 05:26 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Fuse Fuss
There is no VSS spot.
Try the ACC spot.
Happy Racing!
How bout those too scared to drive without headlights in the daytimeand the ones that need headlights for a little rain
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
The_Phoenix
Feb 4, 2016 07:10 AM
