82 T/A Two piece speedo cable?
Old Apr 29, 2012 | 09:16 PM
silentkillzr's Avatar
Car: 1984 Firebird (89 Formula Clone)
Engine: 357
Transmission: m29 T56
Axle/Gears: 3.27 9 bolt Borg Warner.
I have a 82 TA and it seems to have a two piece speedo cable, Im not sure where they both hook into, Can anyone post me a picture of theirs? Thanks!
Old Apr 29, 2012 | 10:20 PM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
Re: 82 T/A Two piece speedo cable?
The '82-83 F-bodies used the old style mechanical cruise control servos. The cable from the gauge goes into the top connection on the servo and the one from the transmission to the bottom. If the cables are just screwed together then there was most likely a problem with the cruise control and it was bypassed.
Old Apr 29, 2012 | 10:39 PM
Engine: 357
both seem to have male ends, i cant see how you would screw it together, I want to make the speedo work, what can i do?
Old Apr 29, 2012 | 11:26 PM
petrolhead's Avatar
Car: '83 trans am Lear Siegler
What is the problem? Are both cables good? If so, it could be in the cruise unit, I just recently took mine apart and found one of the gears inside had somehow moved on its shaft, I pressed it back in place and it works fine now. Otherwise you can get a cable for a non cruise car and install it, bypassing the cruise unit.
Old Apr 30, 2012 | 06:17 AM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
that is what the previous owner did to my car. the PO bypassed the cruse control unit
Old Apr 30, 2012 | 07:24 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Sounds as if you're missing the transducer that Dens71 mentions above.
JamesC
Old Apr 30, 2012 | 07:41 AM
DrewsCam's Avatar
Car: 1991 Z28
Engine: 355 TPI
Axle/Gears: 9 bolt disc / 3:27
Just bypass it...
Old Apr 30, 2012 | 12:30 PM
Engine: 357
How do you bypass it if they are both male ends?
Old Apr 30, 2012 | 12:41 PM
JamesC's Avatar
Chuck the issue with a one-piece cable.
JamesC
Old Apr 30, 2012 | 12:42 PM
Engine: 357
JamesC
Thanks, Do you know length off hand?
Old Apr 30, 2012 | 12:52 PM
KITT1983's Avatar
You need the non cruise control speedo cable they sell them at napa auto parts.
Old Apr 30, 2012 | 01:18 PM
JamesC's Avatar
Sorry, I don't.
My car has a one-piece and cruise. I'd think any one-piece of correct length, or thereabout, would do the trick. (BTW, I don't think that the replacement cable I purchased from GM a few years ago was the same length as the original.)
JamesC
Old Apr 30, 2012 | 08:22 PM
KITT1983's Avatar
JamesC
Speedometer Cable non cruise control
http://www.napaonline.com/Catalog/Ca...RecType%3aA%29
Speedometer Cable - Upper
Speedometer Cable - Lower
Old Apr 30, 2012 | 08:36 PM
Engine: 357
Thanks, ill try that one from napa, thats a good price.
Old May 4, 2012 | 07:28 AM
DrewsCam's Avatar
Car: 1991 Z28
Engine: 355 TPI
That one piece non cruise cable will fix your problem
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
DiabloWS6
20
Dec 11, 2015 04:12 PM
TrevinE
Sep 14, 2015 03:20 PM
TheTraut88
Sep 11, 2015 05:16 AM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
