Should I do redundant switches for my accessories, or run power individually for each
Old May 7, 2012 | 07:14 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Basically wiring a car from scratch for the chassis(ie. non engine) circuits.
And am contemplating this:
I have 6 switches, 1 will be starter engage, 1 will be accessories(generator and other will be on this circuit) (ignition, ignition coils and ECM will be on this circuit), fuel pump, fan, headlights(retaining factory Hi/Lo switch, which appears to power them in either mode, so I will run switched power through to the Hi/Lo switch) And parking light switch.
My question is, should I route all my accessories that I am putting on switches through the accessory switch, ie. run power to acc. switch, then run pwr from acc switch to headlight switch, and park light switch. Or should I just junction block the power near the switch panel, and branch off individually for each switched item. My first time wiring something up from scratch and just not sure which way is more logical.
Old May 7, 2012 | 11:40 PM
Engine: 3.8, 3.4
Re: Should I do redundant switches for my accessories, or run power individually for
Nm, decided it would be best to do a junction block, less risk of drawing too much current through one circuit, and don't lose everything if one circuit grounds out and trips a breaker.
Anyone know a good place to get an insulated junction block for batt +? I looked into it once before and most seemed like they were meant for grounds.
Old May 8, 2012 | 03:58 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Junction Function
SWRaceCars.com has those.
Happy Racing!
If We Don’t Get Cawt We Ain’t Cheatin
BRoss99
Aug 10, 2025 05:08 PM
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
ZsTransAm
Aug 11, 2015 07:30 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
