Where do these wires go?
1 Post
Car: Chevrolet Camaro IROC-Z,96 Vette
Engine: 350 5.7 Liter
Transmission: 700r
First two are on passenger side. One is a single green wire a believe, the other one with two points is gray and black (with purple/pink stripe)
The other one is on the drivers side, that is black and tan (with black stripe.)
Please help it is well appreciated.
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Where do these wires go?
pic#1: The 2 pin is the EGR solenoid, the 1 pin is the EGR feedback switch.
pic#2: Not sure, but I think this might be the infamous "it goes nowhere" mystery connector.
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
Second pic might be the air temp sensor wire connector. On my iroc, there is a jumper harness that plugs into a connector in that area of the engine bay and then runs under the plenum to the air temp sensor. I think thats what the connector looks like for the jumper harness to plug in to. Dont know if your 87 iroc will be the same as my 89.
Glowsock
01-09-2017 04:06 PM
