VATS starter relay location - 88 GTA
Old May 17, 2012 | 09:26 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
It's been asked a hundred times, and the answer is always "driver sude kick panel". Well, mine's not there. The only relay I can find there is the door lock relay. I can't see anything behind that relay, and I can't find anything up under the dash, although so far I only took a quick look. Where can that starter relay be? Every once in a while my car won't crank, so I need to ground the relay, but I can't find it!
Old May 17, 2012 | 09:42 AM
DrewsCam's Avatar
Car: 1991 Z28
Engine: 355 TPI
Axle/Gears: 9 bolt disc / 3:27
Re: VATS starter relay location - 88 GTA
You sure its not behind the gooey tar sheet behind the kick panel? Is this for a gta or your camaro
Old May 17, 2012 | 09:50 AM
juanillox8's Avatar
Car: TOO MANY
Engine: 350 TPI / 350 TBI/6.0L VORTEC
Transmission: T5/AUTO/AUTO
Check above the fuse box getting near the fire wall its gonna have alot of electrical tape around it thats the only other place ive seen them
Old May 17, 2012 | 10:58 AM
Jim85IROC's Avatar
My GTA doesn't have that tar sheet over that hole, because the door lock relay is mounted right in that hole.
Thanks. I haven't pulled the fuse box down to see what's above it. I'll give that a try.
Old May 17, 2012 | 11:19 AM
juanillox8's Avatar
Car: TOO MANY
You dont really have to bring the fuse box down but it makes it easier. it is that area tho
Old May 17, 2012 | 11:38 AM
Jim85IROC's Avatar
Perfect. Thanks!
Old May 17, 2012 | 12:33 PM
DrewsCam's Avatar
Car: 1991 Z28
Engine: 355 TPI
Hope its there
Old Jul 10, 2023 | 01:27 AM
AK87IROC's Avatar
Resurrecting this old thread since I'm having the exact same issue, same car, and had the same idea to ground the relay, and am also unable to find the relay. Jim85IROC, were you able to find the starter enable relay in your 88 GTA?
Old Jul 10, 2023 | 04:22 AM
Reddragon88gta's Avatar
Engine: 5.7 L98
I have an 88' GTA and it was not located behind the rubber/tar paper but higher up and the relay was actually mounted to the body or something else, just remove the driver side hush panel and look for the thick green, thick yellow, small yellow and black wire IIRC and follow it to the relay. There is a picture of those wires further up in the thread. It is tight in there but I disconnected the plug from the relay(I left the relay there), made a jumper with some thick gauge wire with a spade on each end and placed the ends where the large green and yellow wires go into the plug then used a little electrical tape to make sure it wont move.
Old Jul 10, 2023 | 09:47 PM
AK87IROC's Avatar
Thanks very much Reddragon88gta. That's very helpful to know where the heck the relay is actually located in my 88. I plan on doing exactly what you did-a jumper cable between the ignition and VATS wires.
Old Jul 10, 2023 | 10:02 PM
Engine: 5.7 L98
It has worked out well, I also had VATS deleted in the PROM.
Old Jul 12, 2023 | 01:49 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
VATS was on your 88? I was thinking the VATS wasn't on these cars until 89?
Looking on Austinthirdgen.org in their wiring diagrams, the starter enable relay isn't shown on the 88 drawing but does show up on the 89 drawing. I'm wondering if this was a mid model year addiction
http://austinthirdgen.org/mkportal/m..._continued.gif
Old Jul 12, 2023 | 03:22 PM
Engine: 5.7 L98
Oh yeah, it has the window stickers that notify it had anti theft, the chip key etc. I believe the later bulld 88’ GTAs received VATS.
Glowsock
Jul 24, 2025 03:15 PM
Street Lethal
Apr 30, 2019 12:14 PM
Caspar
Jun 19, 2016 11:19 PM
Dialed_In
Aug 20, 2015 01:45 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
