Speedometer and Tach
Old Jun 5, 2012 | 06:09 PM
rodneyrb's Avatar
Car: 1992 Pontiac Firebird
Engine: 04' 5.3 Liter
Transmission: LS1 T56
Hello all, so my car is running and so far, my voltage guage works but thats it. Today I tried to get the tach working with the dakota Digital SG-8 I have the SG-5 for the speedo. I thought I connected everything correctly, I even had a green light on the sg-8 at one point, but the tach never budged. I connected the white tach wire from the c100 to the output of sg-8 as the new pcm outputs my tach signal to input of sg-8. Am I getting this right? I set the 4 pins according to the instructions, but with no luck...
I also am still a bit unsure of where the speedo wire is, this is a 1992 so I dont think there is a buffer box. So I read somewhere.
Thanks.
Old Jun 6, 2012 | 11:06 AM
K4KAK's Avatar
Re: Speedometer and Tach
If its a 92 there is no buffer box the buffer is built into the ecm....I'm going thru the same problem
Old Jun 6, 2012 | 09:27 PM
rodneyrb's Avatar
So I found the problem with my tach issue, I didnt have the sg-8 grounded properly. The tach works now, but it doesnt seem to read high enough. I changed the settings, but it didnt change much (will come back to this). Now for the speedometer. It looks as though my car is a Vin T V6 which looks as though the speedometer signal or vss is not coming out of the c100 like the 1992 v8 versions of this car, it looks like it just comes out under the dash in one of those 2 ecm plugs, red wire I think.
Old Jun 6, 2012 | 09:29 PM
rodneyrb's Avatar
K4KAK, what problem are you having? Have you figured out what wires you need? Are you using the Dakota Digital SG-5 like I am going to?
Old Jun 6, 2012 | 09:46 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
On 90 - 92 cars with the '730 ECM ;
VSS ( Pur / Yel wires ) goes from trans direct to the ECM ( no buffer box like on earlier cars ), then a single wire output to the speedo in dash cluster
Old Jun 7, 2012 | 11:18 AM
rodneyrb's Avatar
Thank you! Thats the info I need!
Old Jun 7, 2012 | 01:15 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The '90 - '92 TBI cars used the 4-out buffer box.
RBob.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Bigold4x4
Sep 28, 2015 05:21 PM
Eric-86sc
Sep 28, 2015 11:37 AM
