My car shuts off at 120mph ?!?!
Car: 1991 camaro
Engine: 3.1L V6 dynomax exhaust
Transmission: 700r4 auto
Axle/Gears: 89 iroc-z 9bolt disc+posi 3.27
How do I disable this.
Let me rephrase my cars power shuts off not my whole car/engine
So I can never exceed 120 ....
Have 145mph cluster
Have 145mph cluster
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
Re: My car shuts off at 120mph ?!?!
Prob the governor that they put mine wouldnt shut Off but bog until the speed gets lower then 110mph then it will kick back up
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
the are two ways of disabling it one in the memcal reprograming or two by using a toggle switch and disconnect the vss signal to the ecm. this will cause a code 24 and if its a 1227730 ecm the speedometer would be disabled when you disable the vss signal.
Linson
Aug 21, 2015 02:12 PM
db057
Aug 11, 2015 10:11 PM
