wiring hell
Old Jun 27, 2012 | 01:40 PM
dablu91's Avatar
Car: all chevys
Engine: 305 and 350 that im rebuilding
Transmission: th350 and th400
Axle/Gears: need to upgrade
wiring hell
I have swap v6 injection to a 305 carb and im trying to figure out my wiring for starting and power to the dash. this is what i have done so far PINK TO HEI ,WHITE IS TACH, RED1 AND 2 POWER, PURPLE IS STARTER, but im not getting the car to turn over. the car does have a vat but i changed the lock cyclinder. so i didnt think that would stop it from starting now. but im not sure how this goes to use the key to start and not a toggle.
Old Jun 27, 2012 | 03:18 PM
91phoenix's Avatar
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
Re: wiring hell
The VATS system has a starter relay behind the driver kick panel. This relay needs to be bypassed. Changing out the key cylinder does not bypass the VATS. With that relay bypassed I am able to crank but with the fuel injection still need proper power for the fuel pump when I swapped to carb. My distributor (Ignition) still had power when hooked to coil as per vehicle it was all pulled from.
Old Jun 27, 2012 | 03:54 PM
dablu91's Avatar
Car: all chevys
Re: wiring hell
would that matter if the fuel pump is on the block?
Old Jun 27, 2012 | 10:04 PM
dablu91's Avatar
Car: all chevys
Re: wiring hell
i caught on to what u said and will look at that tomorrow thank bro for the info
Old Jun 28, 2012 | 09:12 AM
91phoenix's Avatar
Re: wiring hell
Check it out and let us know. With the block mounted fuel pump you need to make sure the original in tank pump is removed and an extension added to the tube to get it to the bottom of the tank. Then it is best if you figure a way to put a factory type in tank pre filter or as I call it a sock. Vats will not affect that at all just the cranking in this case. The best way to bypass is at the relay I mentioned.
Old Jun 28, 2012 | 02:35 PM
dablu91's Avatar
Car: all chevys
Re: wiring hell
thank 91phoenix thats a big help I'll let u know how that works out for me.
AussiePr0nCar
Mar 6, 2020 04:04 PM
mhatfield 14
Oct 24, 2015 07:48 AM
cougar20th
Aug 27, 2015 08:04 AM
86IROC112
Aug 20, 2015 12:18 PM
gta power
Aug 13, 2015 06:15 AM
