Wiring starter up, solenoid won't engage
Old Jun 29, 2012 | 04:56 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Wiring up a starter from scratch, I have power going to the starter, and power coming off it for my feeds the same way the factory did it, and my feeds have power at them, yet for some reason it will not engage when I put power to the purple feed wire, also, if I put a test light to the feed wire it shows its grounded?? Is it normal for it to show ground when not getting power sent to it? I have also tried putting power directly to the wire bypassing the start switch(which works fine) and bypassing the NSS switch as well, and nothing happens, I am nearly certain I have the wire in the correct spot as well, where does the starter solenoid ground at, I am wondering if that is possibly my problem...
Old Jun 29, 2012 | 07:06 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Wiring starter up, solenoid won't engage
Originally Posted by Project 3.4 Camaro
I have also tried putting power directly to the wire bypassing the start switch(which works fine) and bypassing the NSS switch as well, and nothing happens,.
One would suspect the solenoid is faulty then ( assuming you put power direct to solenoid terminal where the purple wire attaches?)
Is it normal for it to show ground when not getting power sent to it?..
Off course
The solenoid has to be grounded to complete the the solenoid circuit for it to work
( how would the 12V power from batt get back to Neg batt terminal otherwise? )
so reasonable to see ground on solenoid terminal
Old Jun 29, 2012 | 07:24 PM
Engine: 3.8, 3.4
Right, but Its a known good starter and solenoid, and as for the ground, that was pretty much my thinking, though I wasn't sure if it should ground when open, or only when closed, perhaps I just don't have enough juice in my battery, but usually if that's the case you at least get something.
Old Jun 30, 2012 | 12:18 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
See starter circuit diagram above
The solenoid circuit is "opened or closed " at the Ign switch end not at the solenoid ;
wire at solenoid just goes through the solenoid coil windings direct to ground
Only thing opened or closed is the main batt feed to starter motor itself
jklein337
Sep 19, 2018 06:23 PM
Derick15
Sep 17, 2016 05:28 PM
Caspar
Jun 19, 2016 11:19 PM
87 camaro iroc
Aug 20, 2015 07:47 AM
