TPI is installed but engine wont start
Old Jun 29, 2012 | 10:01 PM
89demon's Avatar
Car: 91 RS
Axle/Gears: Posi 3.73
The TPI is complete and wiring is done, getting fuel and air and must be getting spark because she will just crank and then POP!....back fire out the of the intake and not start....... I put the engine at top dead center and dropped the distributor back in on 1 and none of the plug wires and crossed but she wont start????? the engine is trying to though. Any ideas?????? It is probably something stupid I'm doing wrong but, any help would be awsome.
Old Jun 29, 2012 | 10:05 PM
89demon's Avatar
Car: 91 RS
Re: TPI is installed but engine wont start
the only thing I could think of is I was reading it wrong and set it 180 out.
Old Jun 29, 2012 | 10:46 PM
Aaron_SK's Avatar
Car: 1985 Sport Coupe
Engine: 3800 Series II Turbo
Transmission: 4th-gen WC T5
Axle/Gears: 3.27 BW Limited
Pull valve cover, watch rockers, find TDC compression, check distributor.
Old Jun 29, 2012 | 11:57 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Pull # 1 spark plug , put finger over plug hole, crank engine over ,
when your finger is blown off the hole you are TDC on the compression stroke.
Rotor should be pointing at #1 plug wire on the dist cap
Old Jun 30, 2012 | 12:43 AM
89demon's Avatar
Car: 91 RS
could it have anything to do with the ECM? I just hope I didn't screw anything up and I repined it right.
Old Jun 30, 2012 | 12:50 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Originally Posted by 89demon
I just hope I didn't screw anything up.
Only testing will tell.
I just hope I repined it right.
You should mention "little " details like that when asking for help because everybody assumes you have a normal functioning TPI setup
that has suddenly stopped working;
not some new setup that you have modified and never started before
Old Jun 30, 2012 | 01:17 AM
89demon's Avatar
Car: 91 RS
Unless the wiring diagram is totally screwed up and BS I do know how to read and passed an my base line mechanical and electrical engineering classes there really shouldn't be any way that the wires didn't end up in the right locations.
Old Jul 1, 2012 | 01:05 PM
89demon's Avatar
Car: 91 RS
well..the car is running just idols roughs...change that fuel pump and bring the fuel psi up where it should be and it should be set to go. oh yea...don't forget to tune it.It should be worth swapping TBI crap to MAF TPI.
Old Jul 1, 2012 | 11:41 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
...change that fuel pump and bring the fuel psi up where it should be and it should be set to go..
So you are saying you have a TPI running on a TBI fuel pump?
Could explain your problems..........................
Old Jul 1, 2012 | 11:46 PM
Aaron_SK's Avatar
Had a guy come in who had done just that. Car would start and run (albeit very lean) but would not rev.
Old Jul 5, 2012 | 02:25 PM
89demon's Avatar
Car: 91 RS
I am not going to be able to continue anything until I get back up north from SC but, yes I do still have the weak TBI fuel pump but, I was never planning on leaving that I have a brand new TPI pump to be installed I just wanted to start the engine up to see if it would fire up and what not. I have done some investigation and it is pretty well determined that when the fuel pump is swapped and the fine tuning is done it will run great.
Old Jul 6, 2012 | 05:51 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I wouldn't start that engine again until a proper pump is in. That pressure is not adequate and the fuel will barely atomize and is probably dropping out very quickly. ECM will try to compensate by raising BLMs. If enough fuel drops out and the ecm raises BLMs too high you could wash the cylinder walls or just flood the engine.
Frozer!!!
Jan 19, 2024 04:55 PM
Wade787b
Sep 29, 2015 01:15 PM
justin57
Aug 20, 2015 07:05 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
drathaar907
Aug 6, 2015 04:20 PM
