no power to ac compressor
Old Jul 1, 2012 | 10:53 PM
77chevymonster's Avatar
Car: 1987 IROC Z
I recently got an 87 camaro iroc z with a 305 in it, but it had been sitting since 95 and had a small problem with rats. They chewed up a lot of the wiring, but i think i got all if not most of the wires fixed. however when i try to get the ac working, the clutch will not engage. I used a test light to see if there was power getting to the clutch, no. But when i wire the Black and green wire terminals to a battery, the clutch will engage... i need help tracing the wires back through everything
Old Jul 2, 2012 | 06:21 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: no power to ac compressor
Welcome to TGO, 77. Perhaps the following will be useful:
http://www.austinthirdgen.org/index.php?pid=19
JamesC
Old Jul 2, 2012 | 08:26 PM
Car: 1987 IROC Z
thanks yeah it helps a lot
Old Jul 2, 2012 | 08:31 PM
Richboll's Avatar
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
You may want to try to jumper the low pressure switch connector to see if the compressor kicks in. Don't run it that way unless you are charging it but its an easy way to see if the compressor runs.
Old Jul 2, 2012 | 08:35 PM
Car: 1987 IROC Z
yeah i did that and it acted like it would engage...didnt have the motor running, but the unit itself seems pretty solid...just an issue somewhere getting power directly to the compressor
Old Jul 3, 2012 | 09:36 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Air Apparent
Using a voltmeter or test light (the type for testing for voltage, not a continuity tester) probe the light green wire on the pressure cycling switch.
Is there power there when the key is in the RUN position and the AC controls are set to AC?
Happy Racing!
My Brakes Don’t Work AT ALL When The Car Is In The Air
Old Jul 3, 2012 | 06:11 PM
Car: 1987 IROC Z
yeah i have a voltage tester, if there is power to the pressure switch, will the compressor be stopped from engaging due to a lack of freon?
Old Jul 3, 2012 | 10:58 PM
Car: 1987 IROC Z
just messed with it a little, no power to the clutch, none to the ac cutoff switch, and none to the two terminals at the top of the condenser, also no blown fuses
Old Jul 3, 2012 | 11:08 PM
Car: 1987 IROC Z
actually the accumulator not the condenser
Old Jul 5, 2012 | 09:10 AM
NINÅ's Avatar
Transmission: 765R4
Air Apparent
In post #5 you implied you heard the comp clutch click.
That’s consistent with power on the low pressure switch.
Not if the rest of the system is good.
just messed with it a little, no power to the clutch, none to the ac cutoff switch, and none to the two terminals at the top of the (accumulator)……
Sounds like you pulled a wire after post #5.
Pull the HVAC panel enuff to probe
light green wire with the key in the RUN position, and the control in the AC on mode.
Is there power there?
Happy Racing!
Spin Me This Week . . . I’ll Spin You Next Week
Old Jul 5, 2012 | 07:11 PM
Car: 1987 IROC Z
yeah it works now had to reconnect the wire, rats chewed through it thanks for all the help
Old Jul 6, 2012 | 04:39 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Thanks for posting back the follow up, it always helps.
And thanks to NINA, of course, for his great help, as always.
Old Jan 20, 2013 | 03:47 PM
curtalert89's Avatar
Car: 91 Camaro R/S
Engine: Tbi 350
Transmission: auto4
Axle/Gears: Stock
I'm having the same problem with my 1988 v6 Camaro, the only way I can get my ac compressor to turn on is if I have hooked to a toggle switch, there is no power going through either of the plug wires that clip into the compressor. The fuse is good as well. Where else should I look for a problem at?
Old Jan 28, 2013 | 04:37 PM
NINÅ's Avatar
Transmission: 765R4
Air Apparent
Using a voltmeter or test light (the type for testing for voltage, not a continuity tester) probe the light green wire on the pressure cycling switch. located on the accumulator (the silver can on the firewall).
Happy Racing!
If We Don’t Get Cawt We Ain’t Cheatin
Old Jan 28, 2013 | 06:03 PM
Car: 91 Camaro R/S
Engine: Tbi 350
Transmission: auto4
Axle/Gears: Stock
Yes there is, I'm thinking it may be the relay, because I disconnected it and switches it with the other and when I do that my car won't start, but when I switch it back it starts up!
Old May 20, 2015 | 07:42 PM
Biggd4355's Avatar
Everything was working, but my AC was howling, so I contacted Oreileys. My warranty ran out two days ago. The manager said don't worry. So I took the old compressor off and an extra plug wasn't on the new compressor. Oreileys said to fill the system, it should be fine. It didn't work. Til I took a metal staple and closed the circuit. Cold air and everything. Then the metal started arcking. I quickly undid it. Now all wires are correctly hooked up, but the fan inside the car doesn't work at all. I can't make the compressor come on so I can refill the system. Is there a fuse I can't find? Shouldn't be the relay, the fan will work on lower speeds if the relay is bad.
evilstuie
Apr 14, 2016 08:52 PM
bryanwood74
Sep 24, 2015 09:50 PM
soarestransam
Sep 1, 2015 04:00 PM
sailtexas186548
Aug 24, 2015 10:11 PM
zayne0
Aug 24, 2015 07:22 PM
