constant 12v easy access inside car?
Old Jul 11, 2012 | 09:14 PM
1986IROCZ355's Avatar
Car: 1986 IROCZ, '00 Grand Prix GTP
Engine: 355, supercharged 3.8
Transmission: 5 speed manual, auto
I bought an aftermarket o2 sensor and air fuel gauge. I wired the switched and constant wires to the radio. Well turns out when the radio is loud the air fuel gauge bounces with the beat. So...I assume its the constant 12v wire.I should change? Is there another constant 12v that's easy to access under the dash or somewhere else close by? Also not sure if I'm in the right section or not for this, but what should I be at at idle, cruising, and WOT? I have a carbureted 355 in it.
Old Jul 11, 2012 | 09:39 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: constant 12v easy access inside car?
Have power seats? Tap into the line for that. There are other lines under the dash that are constant, usually big orange or red maybe pink wires. Just need to probe for them
Old Jul 11, 2012 | 09:42 PM
Do you think its the constant twelve that the radio is drawing? Or the switched? Idk enough about radios. Its aftermarket.
Old Jul 11, 2012 | 10:23 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
No idea what wire you used so i cant comment. No idea why any power feed to radio would pulse a wideband
Old Jul 11, 2012 | 10:38 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Idle and crusing, a carb should run around 14.7. At acceleration, the AFR should drop into 13's but with a carb, who knows where it will take you.
At cruising, a good EFI system will lean out the mixture to 16's (sometimes even up to 18's) to save fuel. But carbs are not equipped to do that. Unless you have a CCC system.
Old Jul 12, 2012 | 07:24 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
You might try the cigarette lighter socket for the 12v source.
Old Jul 12, 2012 | 07:47 AM
Twin_Turbo's Avatar
There's an open BAT terminal on the fuse box, get the proper connector @ vatozone or wherever and plug it in. The connectors for BAT and IGN are different, they do not interchange (for a reason)
Old Jul 12, 2012 | 07:54 AM
nhgator's Avatar
Car: 1985 T/A
I thought I was the only one who called it that
Old Jul 12, 2012 | 08:58 AM
Well I rewired it to a different constant 12v source and still the same. So the next thing I'm going to try is using a jumper wire all the way to the battery and if it still does it, I'm going to change the switched 12v.
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
ZsTransAm
Aug 11, 2015 07:30 PM
apie2546
Aug 8, 2015 07:12 AM
