Issue with my 1984 Trans-Am's headlights
Old Jul 14, 2012 | 08:45 PM
the209bnr's Avatar
Car: 1984 Pontiac Trans Am
Engine: L69
Transmission: THM-700R4
Axle/Gears: 3.73 Posi
Long story short
I was having a difficulty with my driver side light opening up without having to tap on the light itself or helping the motor turn. Then it blew a fuse.. changed the fuse and it was working until recently where it got stuck in the up position and wouldn't lower unless i manually lower it. Now my Passenger side motor is acting up as well it wont lower nor raise unless i help the motor turn.
How hard is it to switch the motors, and would the motors out of a 1987 or 92 trans am work in my 1984? if so would i need to splice wires to make it work.
I cleaned all of the connections and relays and even switched the driver side one and no luck.
Old Jul 16, 2012 | 02:07 AM
the209bnr's Avatar
Engine: L69
Re: Issue with my 1984 Trans-Am's headlights
Bump
Old Jul 17, 2012 | 08:00 PM
SuperHawk996xx's Avatar
Car: 1986 Pontiac Trans Am
Engine: 350 cid bore too much to list.
Transmission: 700-R4
I dont think the headlight motors beyond 87' will work with our cars. The whole wiring system was differnt and the motors are VERY different. The guy at TDS (Top-Down Solutions) can help. He is very knowledgeable when it comes to the headlights and Hatch Pull down motors.
Old Jul 18, 2012 | 11:03 PM
the209bnr's Avatar
Engine: L69
where's that at?
colton_carlson
Mar 8, 2019 12:21 PM
PATRIOTIC1911
Sep 1, 2015 07:26 PM
suzuki949
Aug 28, 2015 08:07 AM
Fronzizzle
Aug 17, 2015 02:52 PM
