blower motor?
Old Jul 21, 2012 | 08:10 PM
Prokilllsx's Avatar
Car: OVRMYHD
Engine: H/C/I LS1
Transmission: 4L60E 3,200 Edge stall
Axle/Gears: 9 bolt w/3.90
blower motor?
The blower motor on Dad's 89 GTA works sometimes but not others. When it works it works on all speeds. I've heard it's the blower motor since there is always power at the motor when tested even when the blower isn't working. It was an L98 350 (it's now an LS1). Question is... Are all the blowers the same? Ebay ones are all listed as for a 3.8 Turbo or 305. It's hard to imagine there is a different one for the 350. Anyone know? Thanks in advance.
Old Jul 21, 2012 | 08:25 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Re: blower motor?
Sounds like the ground wire or connector is intermittent.
Old Jul 27, 2012 | 03:54 AM
Arvizu9618's Avatar
Car: 1985 IROC-Z Clone
Axle/Gears: 3.23 Rear Disc
Re: blower motor?
Only diff i've seen is whether car has A/C or not.
Old Jul 27, 2012 | 04:00 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Re: blower motor?
yep the only difference ive ever seen is between the AC and Non AC.
Old Jul 27, 2012 | 09:26 PM
Coolnyjay's Avatar
Re: blower motor?
advance auto parts has one for $29.99. http://shop.advanceautoparts.com/web...m=blower+motor
I just bought it to see if it drew less amps than the original one. The factory blower draws 21 amps on high. The new one draws 19 amps out of the housing so I think it would draw at least 21 once installed and under pressure. I would suggest buying one and testing it out when your existing one is not working. I just held it in my hand and plugged it in since I was just checking the amp draw. I will be returning it since I never installed it. You could do the same if it turns out to not be the problem. As I was researching the amp draw on the net I saw that some people constantly blow the resistors until they replace the blower. My car is an 89 gta 5.7.
Old Aug 14, 2012 | 05:03 AM
Cat Amanigh's Avatar
Car: 91 RS
Engine: 305 topped w/ Summit Holley Clone
Transmission: 700R4, a placeholder for that T-56
Axle/Gears: 7 5/8, 2.73
Re: blower motor?
Tap the motor gently with a hammer or wrench while it's got power and misbehaving. It'll probably start up when you do this. If it does, it's the motor for sure.
Old Aug 25, 2012 | 12:03 AM
Prokilllsx's Avatar
Car: OVRMYHD
Engine: H/C/I LS1
Re: blower motor?
Thanks everyone. Got it.
Old Aug 25, 2012 | 11:46 AM
Arvizu9618's Avatar
Re: blower motor?
What'd you do?
Old Aug 25, 2012 | 12:25 PM
Prokilllsx's Avatar
Car: OVRMYHD
Engine: H/C/I LS1
Re: blower motor?
figure out which one I need. I'm already sure it's the problem.
Frozer!!!
Jan 19, 2024 04:55 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
zayne0
Aug 24, 2015 07:22 PM
mhatfield 14
Aug 15, 2015 10:47 AM
Street Lethal
Aug 13, 2015 08:28 PM
