Is my rear hatch motor toast?
Old Aug 9, 2012 | 07:21 PM
MParks's Avatar
Car: 1987 Red IROC-Z Hardtop
Engine: Bolt on 305TPI
Axle/Gears: 3:23
My hatch motor just gets really hot to the touch. It works sometimes, but briefly. Other times I have to give it a little whack to make the latch come up. Ill try pushing the little tab to make the latch come up.. then all I hear is a little thump noise in the motor and gets really hot and nothing happens. Any ideas?
Old Aug 10, 2012 | 03:15 PM
MParks's Avatar
Axle/Gears: 3:23
Re: Is my rear hatch motor toast?
nvm
Old Aug 10, 2012 | 05:24 PM
Mailman818's Avatar
Car: 89 firebird bone stock for now
Engine: 2.8L V6
Axle/Gears: B.W 9Bolt 3.27 Posi
Did you figure this out? i had the same problem with mine and have not figured it out. i ended up un plugging it and using it that way.
one thing i noticed was that the housing was broken on it. but im not sure how to remove it to put a new one on.
Old Aug 10, 2012 | 05:39 PM
Cat Amanigh's Avatar
Car: 91 RS
Engine: 305 topped w/ Summit Holley Clone
Transmission: 700R4, a placeholder for that T-56
Axle/Gears: 7 5/8, 2.73
Replace it. It's toast.
Old Aug 11, 2012 | 10:19 PM
waltersb's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Transmission: Auto 4
Motors that get hot and do nothing are toast and can start fires...
Old Aug 11, 2012 | 10:50 PM
MParks's Avatar
Axle/Gears: 3:23
I took the entire thing apart and noticed this little black switch right above the motor. I guess it powers it and is supposed to tell the motor when to go up and down based on the latch "striker" whether the hatch it closed or open. Anyways, Im sure its malfunctioning because when I tap it with a screw driver a couple times it will work for second. The motor still gets hot though so im sure its on its way out, and the plastic housing is cracked. The gear inside was fine. Im getting another used hatch pull down motor/ housing and everything from a friend to save the trouble.
Heres a good video that helped me a lot if you havent seen it already
Old Aug 11, 2012 | 11:06 PM
waltersb's Avatar
There's a good tech article on TGO about repairing and replacing this... it says pretty clearly don't take the cover off the motor :P
Old Aug 11, 2012 | 11:27 PM
MParks's Avatar
Axle/Gears: 3:23
LOL believe me if I saw that, I wouldn't have done it. Such a PITA to get back together
Old Aug 12, 2012 | 12:06 AM
Mikeo91's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Had the same problem with my 91 RS. Bought a deluxe rebuild kit from TDS (top-down solutions.com). Quality Kit with a new motor and reinforced motor housing. About $125, money well spent works great.
Vintageracer
Jan 10, 2020 05:33 PM
madsv1000
Aug 20, 2015 06:45 AM
stalkier
Aug 13, 2015 12:59 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
