Wiring question
Old Aug 16, 2012 | 04:41 PM
al1989's Avatar
Engine: 305 5.0 L
Wiring question
I have a 1989 Camaro RS with a 305 5.7 engine I was trouble shooting the power window switch need to push down on both switches to rise & lower windows. I remove the fuse pannel on the drivers side and notice 4 wire connection missing possibly a relay of some kind. Can anyone tell my what hell goes there and for what?
Old Aug 16, 2012 | 05:24 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Window Of Opportunity
The windows need no relay.
You can post a pic of the connector in question even tho it has nothing to do with the windows.
(Unless the PO modified something.)
The PO put the switches in series for an unknown reason.
Convert them to stock to see if the switch functions go back to normal.
Happy Racing!
Slamming The Wall Is Not The Neatest Way To Remove An Engine
Old Aug 16, 2012 | 07:51 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: Wiring question
The PO that thought they new what they were doing.
Old Aug 20, 2012 | 07:47 PM
al1989's Avatar
Engine: 305 5.0 L
Re: Window Of Opportunity
You can post a pic of the connector in question even tho it has nothing to do with the windows. (Unless the PO modified something.)
Happy Racing!
tTThanks but.
Thanks for the Pics I try DIFFRENT wire connection on the switches and still have the same trouble seems to work only when both switches are press at the same time.Quest still have more trouble shooting to do maybe somthing is cross.
Cleotiz
Jan 6, 2018 08:56 PM
Caspar
Jun 19, 2016 11:19 PM
Bryan F
Aug 18, 2015 02:28 PM
86IROC112
Aug 17, 2015 07:57 PM
redmaroz
Aug 16, 2015 11:40 PM
