Need Help Identifying 3 Connectors
Car: 1985 IROC-Z
Engine: 383
After 6 months, finally putting the finishing touches on the engine & ECM/wiring harness install.
I was in the process of hooking up the other harness (not sure what you call it - underhood or body wiring, it's the harness that plugs in near the steering column and contains the wires for the tach, starter, etc.).
I have just about everything hooked up, but I have three connectors left on the other harness and I have no idea what they go to or if they are even needed any more - in addition to swapping the ECM to the '730, I removed all of the air conditioner components.
See pictures below. The three connectors are:
Connector 1: Two wires, one black and one green. Terminals are perpendicular to each other. Long wires, stretch over to the passenger side and then some. Maybe something A/C?
Connector 2: One red wire. Seems to be about the same length and along the same path as the two starter wires.
Connector 3: 4 wires. Might be a relay harness?
If anyone can help me identify these I would much appreciate it. Thanks.
Car: 91 rs,1 92 rs,92 b4c/1le
Engine: 5.0tbi,5.7 tune port/5.0tpi
Transmission: 5spdx2 and t56
Axle/Gears: 3.08,3.73,3.42
Re: Need Help Identifying 3 Connectors
i think the green and black wired connector may be for the ac and the soild red might be the under hood lite
Car: 1985 IROC-Z
Engine: 383
I thought the green and black was A/C, too. That makes sense.
The red one might be a hood light, but I thought that the people that had the car before had cut the hood light. Maybe not, though.
Thanks for the response.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Car: 1985 IROC-Z
Engine: 383
That is entirely possible. Unfortunately, someone at my brother's shop threw away my old starter so I can't look at see what type of connections it had on it.
There are two wires (separate of this one) that go to the starter - one large, one small. Both have the type of connectors that go over a stud. The new starter I have only has one stud (large) and then a spade type connector. I assumed I'd have to cut the end of off the small wire and replace it with a spade type but now I'm not sure...
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
red looks like a power connection for the AC under the hood as Ive seen that wire hooked up to the ac somewhere in these cars. Could be wrong but ill look at a harness I got here when I get a chance and get back to you. never seen a starter wire that looked like that either
the last connector is for the wiper motor as its the only "L" shaped connector on the car
Car: 82 Z28
Transmission: T400
That is the starter wire from the ign switch that makes the starter work ;
goes on the starter solenoid ( small ) terminal
Factory starters had stud terminals for all connections
Car: 1985 IROC-Z
Engine: 383
I believe it's purple; it seems pretty faded though.
The aftermarket starter I bought only has the one large stud terminal; the only other terminal is a spade connector.
TMZIrocZ350
Oct 7, 2015 12:09 PM
tmork454
Sep 29, 2015 06:33 PM
