HIGH BEAMS ISSUESSSSSSSSSS
Car: 91 rs camaro
Engine: 305 v8
Transmission: 700r
Axle/Gears: 373
im tryin to figure out why my high beams stay on but at low wattage. if you ask me its does look to bad but im sure it needs to be fix. I PUT THE PIC IN MY "TILL THE END PHOTO ALBUM SO PLEASE CHECK IT OUT AN IF YOU CAN HELP ME SOLVE THIS.
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: HIGH BEAMS ISSUESSSSSSSSSS
I would start by cleaning up the ground wire for the headlights.
Car: 91 rs camaro
Engine: 305 v8
Transmission: 700r
Axle/Gears: 373
Car: 91 rs camaro
Engine: 305 v8
Transmission: 700r
Axle/Gears: 373
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
So you mean the hi beams turn on a little when they're not supposed to, when you have low beams only on? Sorry I must be obtuse, what is a 'till the end' photo album? Nothing in your vbgarage.
Car: 91 rs camaro
Engine: 305 v8
Transmission: 700r
Axle/Gears: 373
my photo album or profile photo album. yeah they stay on just alittle for a glow on low beams..
Car: `86 SS / `87 SS
Your headlights may be incorrectly wired.
This thread is lengthy but it has a lot of information about correct wiring. Here's one post about it but the whole thread is good too: https://www.thirdgen.org/forums/post...93-post53.html
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Sorry Rondeezzee, shouldn't post when I've had a couple
Agree with Edwardgp, looks like a typical ground fault. I believe the main beam bulbs have both main and hi beam filaments (I don't have a Camaro). This may be providing some back fed voltage from the main filaments thru to the hi beam filaments, enabled by a bad ground.
LT1Formula
Oct 8, 2015 08:34 PM
