My car won't shut off
Old Aug 18, 2012 | 12:28 AM
McGregord7's Avatar
Car: 1987 Camaro Z28
Engine: 305tpi
So I've ran into a problem, my car fires up and runs perfect everytime I turn the key, but when I turn the key off the car keeps running perfectly even revs and will shift into drive and such. If I turn on just power and turn the key off that works but if I start the car and turn the key off it won't stop I can even take the key out and unplug the battery and it keeps running
Old Aug 18, 2012 | 12:37 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: My car won't shut off
Your alt is back feeding the car.
More info is needed tho..
Old Aug 18, 2012 | 03:11 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
A little info on your car ( year , motor , mods etc ) goes a long way to getting accurate help
Fill in your profile ( in the user control panel at top of page ) so guys know what you have got
I can even unplug the battery and it keeps running
Originally Posted by TTOP350
Your alt is back feeding the car..
With the battery gone only place engine can get power is from the Alt
Old Aug 18, 2012 | 09:22 AM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
there needs to be a diode,light bulb,or resistor in series with the alternator
"turn on"wire-alternators meant for"guage"clusters have the resistor
built in,but "warning light" ones do not-a small bulb such as #194 will
stop the backfeed.
Old Aug 20, 2012 | 03:03 AM
McGregord7's Avatar
Engine: 305tpi
It's an 1987 camaro Z28 305tpi 700R4.
So your thinking more of an electrical problem is what I need to look at?
justin57
Aug 20, 2015 07:05 PM
ZsTransAm
Aug 11, 2015 07:30 PM
djmarch
Aug 9, 2015 05:27 PM
Fronzizzle
Aug 9, 2015 01:15 PM
