attaching gnd straps
Old Sep 5, 2012 | 09:41 AM
budget builder's Avatar
Car: 91RS
Engine: carb'd 357 vortec
Axle/Gears: 3.42 posi
If I'm wrong tell me I have new vortec heads and have the big ground from the battery to the passenger head acc. hole. has anyone ever experienced a problem where this big wire does not make a good ground connection even thought there is no paint where I have the bolt screwed in?
Old Sep 5, 2012 | 01:50 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: attaching gnd straps
Same hole for Alternator mount // bracket from battery negative?
Or is it behind the head, going to the firewall?
Old Sep 6, 2012 | 08:23 AM
Car: 91RS
the problem is the small grounds ( batt to fender, engine to firewall) are getting really hot when trying to crank. I did some reading and learned that it could be the solenoid, a bad ground connection, the 20year old ground from batt to front passenger cyl. head needs to be replaced, or it is too small because the starter could be pulling more current to turn the tighter new 355 engine. does any of this sound at least feasible? help me out. I will be replacing the 20 year old wires anyway with a bigger gauge prolly 2awg. and new terminals
Old Sep 6, 2012 | 08:55 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
IMO I would start by cleaning every ground I could find. Taking them apart sanding, cleaning, maybe a new bolt, and painting. Put every ground you have and maybe some extra on. The ground from the battery to the chassis included.
Old Sep 6, 2012 | 10:09 AM
Car: 91RS
ok i'll go and get some new ground straps and definitely new/bigger ground cables and do: batt to fender, batt to engine, engine to fire wall, engine to subframe, and batt to subframe
Old Sep 7, 2012 | 10:27 AM
Car: 91RS
I have a: 2awg battery cable to go from batt to engine
4awg cable to go from engine to subframe
1in x 12in braided cable to go from engine to body
1/4in x 15in braided cable from engine to firewall
I will sand off paint to get to the bare metal and any dirt on the subframe and rough up the bolting surface of the ground wires before connecting. all wires are NEW. AN old starter repairman was the one who told me to stop looking at the starter either my wires were dirty, loose, or just too old and may have broken connections or corrosion. so if its not grounded by the time I get finished then I look at the starter and solenoid.
Old Sep 7, 2012 | 11:46 AM
Edwardgp's Avatar
Engine: 454-350
That should take care of it but one more thing I do is after its all back together I hit the connections with paint. Good luck and let us know what the heck is going on.
Old Sep 11, 2012 | 05:50 AM
Car: 91RS
2awg ground batt cable fixed the prob.
Linson
Oct 24, 2025 02:00 PM
MrPackstin
Oct 25, 2017 08:09 PM
gord327
Oct 3, 2015 01:25 PM
Linson
Oct 1, 2015 09:50 PM
92projectcamaro
Sep 29, 2015 07:07 PM
