aftermarket temp sensor and gauge????
Old Sep 8, 2012 | 04:39 PM
thegoon1969's Avatar
1998 350 with rpm intake, carb, cap in coil and no computer.
Im trying to get my aftermarket temp gauge and sensor to work. the gauge has three prongs on the back. one for a key on 12v source. one for the sensor/sending unit and one for the ground. Seems strait forward enough but when i hook it up it doesnt work. I currently have the sensor installed near the tstat housing on the aluminum intake manifold. I hooked it up exactly as the directions say. it still doesn't work what am i doing wrong???
check for 12volts with key on at back of gauge, its got 11.89 volts with the key on. check for continuity on the load wire and its good. the ground is good. HELP PLEASE!!!
Old Sep 8, 2012 | 04:41 PM
Re: aftermarket temp sensor and gauge????
also i noticed that if i remove the ground from the back of the gauge and run a wire from the ground to the base of the sensor on the intake then the sensor will work. what the ****???
Old Sep 9, 2012 | 06:06 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
what the ****???
So you have a ground problem somewhere.
The ground you are using for the gauge is not at the same potential as the ground for the sender unit;
hi resistance / broken wires ,bad connections on the grounds somewhere , etc
Old Sep 10, 2012 | 04:00 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Common Sense-or
Your description of your problem is consistent with the sensor not being grounded.
You didn’t use Teflon tape or anti-seize did ya?
Happy Racing!
How bout those too scared to drive without headlights in the daytimeand the ones that need headlights for a little rain
hydrolic144
Oct 4, 2015 08:23 PM
GTAman
Sep 21, 2015 09:57 AM
Bstrang6
Sep 8, 2015 04:29 PM
Wife'sCar
Sep 5, 2015 08:58 AM
