HEI recommendation for a 350 5 Speed Combo
Old Sep 11, 2012 | 04:58 PM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
Hi, I currently have the electronic Q Jet on the car, I have a Gm 350 along with a 5 Speed, My other mods are in my Sig Below, Just wondering what carb is recommended, It is not a daily driver but I am looking for a good reliable carb,I am also looking for an HEI Dist to go along with it.
By Changing the Carb and Dist is there anything else I need to do? can I just take the Check engine bulb out and worry about it after this?
Old Mar 1, 2013 | 07:50 PM
BLACK Z's Avatar
Car: 86 Z28
Re: HEI recommendation for a 350 5 Speed Combo
Anyone?
Old Mar 1, 2013 | 08:04 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The stock carb and distributor will work fine.
Old Mar 1, 2013 | 08:22 PM
BLACK Z's Avatar
Car: 86 Z28
I have been having a Backfire issue for years with the car, it is constant out of the exhaust on decl, They only thing that made it change was when I disconnect the 4 Pin connector that goes to the Dist, SO I would like to change these parts out and see if that is the issue. I figured changing the carb and HEI may fix issue. I have been chasing the problem for ten years now.
Old Mar 4, 2013 | 08:55 PM
BLACK Z's Avatar
Car: 86 Z28
Well I ordered these today, hope I made a good choice.
http://www.holley.com/0-76650BK.asp
http://www.summitracing.com/parts/msd-8365
Old Mar 4, 2013 | 09:56 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Decel pop is likely not distributor related. Could be timing and airfuel related but thats from the chip tune and not actual distributor. Could also be air leaks in exhaust.
Old Mar 5, 2013 | 05:19 AM
BLACK Z's Avatar
Car: 86 Z28
I tried different exhausts, I even smoke tested the exhaust and verified no leaks, the only thing that helped was dist dist 4 pin wire orif I gave it a touch of gas on decel.
Old Mar 5, 2013 | 07:16 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Could be lean pops. Usually ecm pulls fuel on decel and the timing thats left in during that low load higher rpms area is high. If its causing the pops it may want less timing. Wont get the strong engine brake feel when decelerating with less timing. It may want more timing but i am not exactly sure what the distributor defaults to when the 4 pin plug is pulled out. I assume base?
Old Mar 5, 2013 | 07:49 AM
BLACK Z's Avatar
Car: 86 Z28
I believe it is base timing, I think it takes out all of the electronic advance.
Old Mar 5, 2013 | 07:51 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Base timing and a small amount of advance as speed increases.
BLACK Z's Avatar
Car: 86 Z28
I hope the MSD DIst works well, I know it wasn't cheap.
Old Mar 5, 2013 | 08:02 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
I dont find anything wrong with gm small cap remote coil setups. Tuning for air fuel and timing likely will help more unless something is wrong with yours. If it seems to run fine normally and verify correct timing at balancer vs commanded, then new dizzy isnt the issue. Its a spark/tune thing. Could just program computer to command less timing if that helps reduce popping
Old Mar 5, 2013 | 08:28 AM
BLACK Z's Avatar
Car: 86 Z28
Don't know how and don't have way of burning new proms.
Old Mar 5, 2013 | 12:59 PM
MKM's Avatar
MKM
Car: 88 Trans-am GTA
Engine: 400 Small block
Axle/Gears: 3.42-3.73
When I was tuning my Gen 7 I had this problem all it was was unburned fuel in the exhaust I program the fuel to shut off on deaccel no change in timing problem solved.
Old Mar 5, 2013 | 06:15 PM
BLACK Z's Avatar
Car: 86 Z28
I have no way of programing the proms.
Old Mar 6, 2013 | 08:10 AM
MKM's Avatar
MKM
You may want to also check your injectors to see if they are leaking, could also cause this problem.
Old Mar 6, 2013 | 08:41 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
There are no injectors in his carburetor.
Old Mar 6, 2013 | 09:40 AM
MKM's Avatar
MKM
May bad than that is even easier sound like the butterfly's are not closing all the way. Does it ever stay running after the key is turned off?
Old Mar 6, 2013 | 07:50 PM
BLACK Z's Avatar
Car: 86 Z28
No it does not the car runs perfect accept for the backfire on Decel.
Old Mar 6, 2013 | 08:12 PM
MKM's Avatar
MKM
What rpm is it idling at?
Old Mar 7, 2013 | 08:59 PM
BLACK Z's Avatar
Car: 86 Z28
Idles some where around 750 when the choke is not on.
Old Mar 8, 2013 | 08:27 AM
MKM's Avatar
MKM
Well if it is idliing correctly the only other this is timing. I have seen some after market module do some strange things also to much timing. Also ditributor shafts worn out can cause some wierd things to happen, but usally cause other drivablity issues.
Old Mar 8, 2013 | 10:02 AM
BLACK Z's Avatar
Car: 86 Z28
Tried stock module and a accel one
Old Mar 8, 2013 | 10:50 AM
MKM's Avatar
MKM
How much advance are you running?
Old Mar 8, 2013 | 12:00 PM
BLACK Z's Avatar
Car: 86 Z28
8 initial and then what ever the elec brings in.
Old Mar 8, 2013 | 12:41 PM
MKM's Avatar
MKM
I don't know what the specs are for that set-up but I know a tpi is 6 initial. May just try some different timing settings just to see what it does. Try 0 initial and go drive and see if there is any change maybe your getting to much advance, also rev it up in nuetral and check to see how much advance it is getting.
Old Mar 8, 2013 | 02:08 PM
BLACK Z's Avatar
Car: 86 Z28
I had tried changing the time from 0 up to 10 same issue, I forgot what the total was.
Old Mar 8, 2013 | 04:07 PM
MKM's Avatar
MKM
Well I'm out, still think it is getting fuel when it shouldn't. If you figure it out let us all know I would be curious. Good Luck.
Old Mar 8, 2013 | 04:28 PM
BLACK Z's Avatar
Car: 86 Z28
I am going to try new carb and dist and see if that fixes it, I just got them today, Going to be a bit before I get them on.
Old Mar 8, 2013 | 04:31 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
At high RPM with the throttle closed the manifold vacuum is high enough to pull fuel straight out of the idle ports, which then burns in the exhaust.
You've got pretty much the worst of all possible worlds for causing deceleration pop... A fuel injection system would cut fuel during deceleration. A more sophisticated EGR system would allow exhaust into the manifold to reduce vaccum. A deceleration bypass valve would lean out the manifold charge. A catalytic converter would burn up some of the excess fuel. A stock muffler would almost completely absorb the noise. An automatic transmission with an overrun clutch would lower engine speed.
Old Mar 8, 2013 | 04:59 PM
BLACK Z's Avatar
Car: 86 Z28
I have a egr system on it now, I have tried it it with a cat,hollow cat and a straight pipe no change. I have had other carb combos in this car and never had a problem, THis motor is the only one giving me this issue.
Azrael91966669
25
Jun 20, 2017 04:04 AM
fbirdroller
Sep 2, 2015 10:27 PM
Eric-86sc
Aug 24, 2015 09:01 PM
theurge
Aug 21, 2015 12:46 PM
midias
Aug 15, 2015 05:07 PM
