Wires in front of rear seats.
Old Sep 23, 2012 | 06:08 AM
crazybird's Avatar
Car: 1987 firebird
i got a set of two wires routed inside the black plastic loom running in front of my rear seats. the wires are blue and black or white and black i think. 87 firebird.
Old Sep 23, 2012 | 07:40 AM
Stauf's Avatar
Car: 91 Z28 Coupe
Re: Wires in front of rear seats.
Wires are for intank fuel pump.
Old Sep 23, 2012 | 02:44 PM
crazybird's Avatar
Car: 1987 firebird
I see the fuel wires, but these two wires split off and run up the passenger side rocker and back behind the dash.
Old Sep 23, 2012 | 08:29 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Fuel gauge sender?
Old Sep 24, 2012 | 10:28 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Passenger side rocker? That does not sound like the fuel tank wires, those go up the driver side. And the color do not match either.
The fuel pump power wire is tan/white and the fuel sender wire is pink or purple.
Where does the other end of the wires go, Crazybird?
Old Sep 24, 2012 | 11:33 AM
crazybird's Avatar
Car: 1987 firebird
They go from the passenger side kick panel along the rocker, cross over the "hump" in front of the rear seats. I think from there it goes to the rear of the car. the fuel pump has two wries coming off of it. These are not those two wires.
Old Sep 24, 2012 | 11:44 AM
BigBadLou's Avatar
Engine: TPI
When the wires cross over the hump, do they go directly under the seats or do they continue to the side of the car where they disappear under the plastics of the sail panels?
It would help to know the exact wire color, when you get a chance to verify, thanks.
Old Sep 24, 2012 | 12:04 PM
crazybird's Avatar
Car: 1987 firebird
The do go all the way to the plastic. There are a total of 4 wires that are in front of the seats. the black and yellow wires are the ones in question.
Old Sep 24, 2012 | 12:29 PM
BigBadLou's Avatar
Engine: TPI
Black and yellow, gotcha.
Black is normally ground. And yellow is a standard color for the left rear turn signal. Also, some years, GM used it for the third brake light. Though the wires never cross over from the passenger side to the driver side, which is puzzling at this point.
One other possibility is that the wires are aftermarket, let's say for an amp installation in the trunk, alarm etc.
I would definitely probe the yellow wire with a test light and see when there is power to it (while applying brakes, with turn signals on, with key on, with radio on etc). It should help us determine its function.
Let us know what you find.
Lou
Old Sep 24, 2012 | 12:32 PM
crazybird's Avatar
Car: 1987 firebird
Its defnately not aftermarket. it is in the black plastic and has factory clips all around connecting to the body. I dont have a test light. I guess I will just start removing plastic and trying to trace its origin.
Old Sep 24, 2012 | 12:55 PM
BigBadLou's Avatar
Engine: TPI
You can get a test light for a few dollars (Harbor Freight often has them on sale for 99c).
Or you can use a voltmeter.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
